yep i need piping andf all ive been to few places spoken to steve there all booked out till after christmas i got one qoute fromt civilised automotive for $890 with fitted with stainless steel piping boost controller installed and boost guage doesnt seem to bad hes available to do it thursday ready friday what do u guys think 2 much???
https://www.sau.com.au/forums/topic/6525-place-for-coolers/#findComment-98083
Have you seen the work dandy exhausts do? They are Farkin good, And I speak from experience, $890 is a bit pricey, They should only charge you about $600, Mandrel Bends are damn expensive, bout 60 bux a bend or something. Id wait for dandy exhauts, it'll look neat and its a good job. They know their stuff.
Sam
https://www.sau.com.au/forums/topic/6525-place-for-coolers/#findComment-99620
Sam
WELL *** ME OVER WITH A BLOW TORCH AND SEAL ME UP WITH A OXI WELDER! where in gods name have u been??????
https://www.sau.com.au/forums/topic/6525-place-for-coolers/#findComment-99622
Sam
OMG! What hole in the ground did u stcik your head out of and decide to post sumthing on here?
https://www.sau.com.au/forums/topic/6525-place-for-coolers/#findComment-100663
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
