Retail for the RB20 engine is around $600. This is a monotorque set with imported gaskets and seals from Japan. Most likely some genuine parts in there.
Ring someone like Autobarn or Repco. They will be able to get you a price.
The RB25 should be around the same. I can probably get one for $400 for you if you ask nice. Of course you would have to pay for postage.
I have a genuine Nissan RB25DET VRS kit you can have for $250 (brand new).
The only extra bits you get with the full gasket set are:
- front crank seal (about $16 for genuine)
- rear seal ($50)
- oil pick-up o-ring (??)
- oil pump gasket (??)
[don't think I've missed anything ??]
I don't believe you get any turbo gaskets with a 'full' set (except for the ex manifold gasket), and there is no sump gasket (just use 3-bond).
my car just came from japan and i noticed an oil leak from the rocker cover...so i thought i just get the engine all checked and do a MAJOR MAJOR service including changing every oil that can ever be changed on it. It's a pitty that the car is gone for compliance and its been 2 weeks already and still canberra is to send the plates down, the guys think it'll take another couple weeks. : ( Thanks ppl i appreciate your info.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
