so what i was bored. wasteland dude, dont take it so seriously
Yeah we realise its the wasteland, but FARK OFF back to SA and waste away over there with your one word posts :kick:
Its about having fun but there is a line and your flirting with it!!!
is it just me or does the fact that a mainlander started the post whore thread  and calling it whoretown,  make you want to start doing what the cascade ads do? :rant:
now im talkin in tassie code
ps im moving to gold coast one day hahaha
BWAHAHAHAHAH thats a classic.
Dont think to many mainlander would get that. Hell i dont think to many Tassie's will get it either :Pimp2:
is it just me or does the fact that a mainlander started the post whore thread  and calling it whoretown,  make you want to start doing what the cascade ads do? :(
those cascade adds are crap they shit me to tears !!
