hahah nah thats just ur natural aroma  :P
Look here missy, unless your willing to rub "pie" in my face then thats enough out of you :)
And i smell lovely, you can't beat that petrol/oil/grease/sweat" smell.
Its called EAU DE CAR and coming to shops near you soon :D
Cheers B
honestly.... lamest comeback ever :P
check my profile dude i dont even live in darwin..... opposite end of the country bud :lol:
honestly.... lamest comeback ever :O
How about quoting the right quote then arse breath if your going to make a comment like, otherwise it just makes you look like more of a jack arse :lol:
jk
Darwin, Victoria its all the same rubbish isn't it :D
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
