Thought I'd post in here, I'm having a think about possible moving to Tasmania down the line, probably had people ask this before, but whats it like down there? Currently in canberra. Is fuel more expensive? And I take it theres a few half decent import mechanics in hobart etc?
From what I heard as well the economy isn't going to bad either? I'm only just starting to think about it, but just after some info, I work in IT.
wow whoretowns busy in here lol :)
Good to see some interest in Tassie mate! It is a good place to live. The car scene is starting to liven up down here and the fuel is no more expensive than what you pay in ACT. If you work in IT, there is plenty around in your field but prob not as much coin compared to mainland prices. My mate works down the west coast as an IT guru at a mine site and he's on a good package. Come down for a cruise one weekend and check it out.
There is always the TasCommodores organised East Coast Cruise this weekend you could join in with.
Invited pretty much anybody along as long as they behave naturally.
When: Sunday 16th November
We will be meeting at the Campbell Town football oval (just north of town centre) at 10.30am in preparation for an 11.00am departure.
We will be heading east through Fingal and St Marys to St Helens where we will stop for lunch.
Then continue north through to Scottsdale and back to Launceston via the Sideling.
The cruise will entail approximately 280km and should take somewhere in the vicinity of 4 hours including the stop for lunch.
Was an absolute blast a couple of years ago in the Hatch. Not so much fun last year in the Adventra.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
