OK, last week was a big disapointmnent 4 me and my car, it wasnt boosting bast 9psi.
I found the issue, the hose from the gate to the boost controller was burnt and it was leaking boost.
Thats fixed now with some stronger hose and some heatsheilding.
So she will be reading and going this week seeing 12's
(i wont be driving it much but my mate will)
So hopefully ill see you there
I have been told the new times are 6pm-10pm..... not 100% sure
See ya there..
Crag
https://www.sau.com.au/forums/topic/65360-wsid-street-meet-wed-23-2-05/
  • Replies 115
mmmgtir: The funny this is when the venue first opened I thought about getting a season pass until I seen the prices (from memory it was about $600+ just to spectate). I thought no way that is too expensive i'll never spend that much there...
Since that comment i've been to every single wed nite event that has been held including competiting at about 7 events :(
That place owes me well over $1,200 just from spectating/competing/food/merchandise ;)
Famous last words eh...
Gee birds fly fast these days... what type of birdie was it?
Yup just gave them a clean actually... that's gotta be worth atleast 0.05sec by itself...
Hopefully I have a new PB tomorrow night, no promises... might take a meeting or 2 to get the feeling for them (plus the right psi for my setup). Anything sub 2.0sec 60ft and it will be worth the purchase ;)
see you all there, i fixed my boost l;eak so ill see you in the 12 second passes
GO BEN BRING HOME THE 13', those nittos will help you get out of the hole quicker
(can i borrow them, only kidding Good luck and ill see you there)
Buster, i Will be driving but io want my car to do a good time so Glen (IRB26T) is gonna drive it 4 a few runs..
mate I didn't post anything, it was Blitz who asked why you weren't driving :( hahaha
good luck everyone fingers crossed for pb times all round
well 4 those that stick around u would know how pised i am,
last run of the nite, doing 170Kms at the end of the track and what happens, my bonnet flys up smashing my windscreen, putting a massive dint the size of my roof, and smashing my bonnet
F**K S**T C**P GGGGGGR NOT HAPPY JAN
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
