  • 2 months later...
  • Replies 84
ive just receantly bought a r32 gtr and it came with a switch in the boot to change from 4wd to rwd . all i have to do is while the cars turned off press the button then switch the car on and the 4wd light comes on (no other lights come on)then if i want 4wd just do the same thing . i havent been game enough to drive it in rwd drive yet lol. anyway heres a pic of the switch
  • 1 month later...
How do people dyno a GTR on a 2wd dyno? Do they take the front drive shaft off? If this is the case, wouldn't gear oil spill everywhere?
i got a R34 with AWD, and i always disconnect the AWD and make it RWD, all u gotta do is find the electrical plug near the diff under the car on the driver side. its a black squarish shape and you should see it easily, it disconnects the front wheels like 100% just take a look at my pics :D
I hope you've got the money tucked away to get a new transfercase. R33 and R34 transfercases have preload on the clutch packs (which will likely overheat them without electrical power to the ATTESSA system), this trick should only be done on the R32's because they don't have any preload on the clutch packs. It's why any smart dyno operators drop the front shaft with R33/R34s.
  • 2 months later...
i got a R34 with AWD, and i always disconnect the AWD and make it RWD, all u gotta do is find the electrical plug near the diff under the car on the driver side. its a black squarish shape and you should see it easily, it disconnects the front wheels like 100% just take a look at my pics smile.gif
I also have an R34 AWD. i pulled the fuse once on grass and gave it a little kick and its definately rear wheel drive. just didnt keep it off incase i ruined something (transfer case) so reading through this thread a few people have said remove shaft and others have said to bleed something. i dont know how to do either of these. is it ok if someone explained to me how to do it safely.
cheers.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
