Hey guys and gals,
there is a very very high possiblity i will be moving to Sydney for work in the very near future. Just wanting to get some info from you locals and find out where everyone lives and if its not to personal, roughly what sort of rent id be looking at for that area. Will be working in the city and dont mind commuting but at the same time dont want to be on a bus/train for an hour there and back.
Only really need a 1 maybe 2 bedroom as its just me and my girlfriend. Would like a decent area but am not overlly fussy.
Im sorry this may be a really broad question but i cant really be anymore specific. Any help will be greatly appreciated.
Cheers,
Steve
https://www.sau.com.au/forums/topic/65401-where-to-live/
well I live on the lower north shore and like it there. about 25mins to the city by public transport or 20 by car. rent for a nice 2 bedroom place would be around 350 upwards. If something a little more trendy and closer to the city is more your thing you should look at the inner west:
stanmore
enmore
newtown
leichardt
etc
are all good. I've just bought an appartment in stanmore that will be up for rent soon. looking for around 380 for it. 2 bedroom plus lock up garage etc.
best you start looking at real estate sites to get a feel for things.
https://www.sau.com.au/forums/topic/65401-where-to-live/#findComment-1222416
I only moved to oz 18 months ago, and about 12 months ago bought a place down in sutherland shire, just outside of sutherland, 3 bed, double garage, 650 Sqm corner block, pool, nice cathedral type cedar celings, paid 580k, then spent another $30k on rennovations ... worth in excess of 650 now aparently ....
sister in law is also looking to purchase a flat closer to the city, ashfield type area, shes looking about $300k for a nice 1 - 2 bed apartment with parking space ... seem to be a lot of them around for that sort of $
hope this helps a little
https://www.sau.com.au/forums/topic/65401-where-to-live/#findComment-1222493
Sorry tango looking to rent. Thanks anyway!
https://www.sau.com.au/forums/topic/65401-where-to-live/#findComment-1222516
places in Manly/Harboard/Dee Why on the northern beaches are going for 350 upwards for a nice 2 bedroom apartment.
The Northern Beaches are a fantastic place to live. fairly laid back lifestyle, beaches close by and a generally safe area.
Bus to the city would be around 45 mins I would think or if you live in Manly you can get the ferry across to the city. wouldn't be a bad way to get to work each day :)
https://www.sau.com.au/forums/topic/65401-where-to-live/#findComment-1223144
Teh inner west rules!
I've lived eastern subs, western subs, lower north shore & now the inner west since I moved to Sydney at the end of '96. I'd say that the west subs have the lowest living expenses, the lower north shore was the most green (established parks & trees everywhere), the eastern subs are close to beach without being far from the city & the inner west is the most fun & conveniently close to the city.
300 - 400 for a newish 2 bedder & security car space. I share a 3br, 1y.o. apt in Leichhardt that costs 440 between the three of us but I want to move further in (Newtown, Camperdown)
https://www.sau.com.au/forums/topic/65401-where-to-live/#findComment-1223288
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
