My Intercooler arrived today, hooray!
No time for the install today, been having turbo timer/alarm problems. hopefully tomorrow, and i'll get pics up of the whole effort.
Just so people know, it's a specific Stagea E-WGNC34 kit from Greddy, but has Trust on the box too. It's got a return pipe, so uses stock intercooler piping which means no cutting into chassis for me. Looks really simple to install, but i'll find out tomorrow.
Core size is 600 x 250 x 76mm
https://www.sau.com.au/forums/topic/65404-wooo-fmic-time/
Hey guys, i finished installing my FMIC today. Now, i haven't figured out how to post the pictures into the post, so i've just uploaded them.
Basically, i pulled the entire front bar, plus bumper support off after raising the car. The kit said the old transmission cooler had to be moved, so i relocated the transmission cooler with the parts that came in the kit to in front of the washer bottle. the old intercooler was a pain in the arse to get out, probably because it had been there for 9 years. Taking out the coolant bottle helped a lot.
After that, i had to cut a piece out of the bumper support, which i just used my jigsaw. i broke 2 blades doing this however. A fair amount had to be cut out of my front bar as well, but i forgot to get photo's of that.
The FMIC was a bit of a tight fit, but after a bit of fiddling it all bolted in nicely. A sensor at the front had to be bent out of the way and one of my horns was relocated.
The piping went in without a hitch, perfect fit, not worries.
After cutting a bit more out of the front bar, because i'd missjudged, it all went back nicely together. the FMIC is still very subtle behind the front bar, and you can hardly see it at all unless you were looking for it.
All in all, i'd give the GReddy Stagea FMIC Kit 8/10, it was all in japanese, and some pictures weren't too clear one what exactly was being done.
https://www.sau.com.au/forums/topic/65404-wooo-fmic-time/#findComment-1224499
You only broke two blades? How many knuckles? :( That looks like some pretty serious cutting for a kit that just 'bolts in' - good effort, looks like a good job!
https://www.sau.com.au/forums/topic/65404-wooo-fmic-time/#findComment-1224697
It does pull a little harder now. I hadn't driven it until i'd posted those photo's up. once i gave it a bit, and did a high speed drive (100kph) i noticed it did take off a bit better. the lag in 2nd seemed less noticable. it's not a massive power upgrade, but it's a good start. all i need now is a CAI box to make it complete
https://www.sau.com.au/forums/topic/65404-wooo-fmic-time/#findComment-1225157
Great stuff there!
Im not a big fan of the pipe running under the intercooler, but I guess it would be no different witht he rb25 as the bloody inlet manifold runs back over the motor anyways so it saves it going through the engine bay.
Im keen to see the power difference from this, how much boost are you running?
https://www.sau.com.au/forums/topic/65404-wooo-fmic-time/#findComment-1225778
Yeah i'm getting more power at higher speed, well that's what it feels like.
and the clear front indicators came with the car, sorry mate, can't help you there. Same with the grill and eyelids. all part of the bargain i got :)
https://www.sau.com.au/forums/topic/65404-wooo-fmic-time/#findComment-1226097
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
