  • Replies 42
rrrage interior looks clean as... good pickup.
Best thing for u to do would be justb to swap the position of the CD player and the TV around... very easy and should only take about half an hour. I had to do the same thing with the TV in Josies Soarter cause when u put it in park and the TVs out it wont go in properly.
as for wheels... on a black R32 the best is to go white with the stock wheels... white on black looks good.... black on black looks pox... and we wont even go into gold stock rims. at least the stock 32 rims look good... unlike those cheap nasty looking R33 rims... worst... ever.
cheers gojira ... will take that into account. we did some hard driving and braking while testing it out and the tires seemed okay, but i'll have a talk to the people that matter about it.
Yep... good idea. Mainly look on the sidewall at the treadwear, anything above 300 would concern me on a performance car.
Also just check, I think the tyres are mounted in the wrong rotation direction as well. :headspin:
Awesome rrrage!!!! Im looking for exactly the same thing, stock black 2 door 32gtst!
you said that you had to have it complied.. does that mean that the person that your buying it off only bought it in jp and landed it? I didn't realize ppl did that.
congratulations can't wait to see it sometime in the not too distand future.
foz... there were, before the 15 year rule change many guys here who have a japanese contact who buys cars, they import them and sell them off here for a profit... he included compliance and road worthy in his price.
hah you're right, the triangular pattern should point forwards! will just have to swap left with right
ahem.
I wouldn't say that. (not a good pic but u get the idea)
http://www.skylinesaustralia.com/forums/at...achmentid=31807
Yeah, the triangular patter should face backwards shouldn't it... will have to swap the right side rims wiht left.
"Roys 32 is to Motorsport as vaginal bleeding is to fellatio"
ROFL...Thats gold. You are quite the wordsmith:)
What saddens me is that your keen observation is true:(
Beat up on me and my R32, but rrage's R32 is virginal and shoudlnt be tarred with the same brush. :(
Oh hang on..you did say Roys R32:( ...... :(
...and Shiv :whackit: me likes :P
ahem.
u cant even tell what rims they are spaz.
lmao
sorry couldnt help it after i saw ur sig.
I posted that same pic on another thread and ppl spotted the type of rim.
TE37's doofus. :P
Roy - thanks dude. Its good to finally have it. I took it for a spin (closed roads seeing as its not registered yet) and it was a pretty amazing feeling. I still miss the GTS-T tho :(
Shoulda kept it
Shiv....Well ill have to add you to my list of cheaters who i must destroy:)
Or continue to blow up trying to beat:(
...inark, get your cameras ready. Idiot me is going to give this grift...i mena drift thing a go, just have to find someone to share some real nasty 16x6" rims with:)
...about my sig, i hope ppl realise im taking the pi55:) Anything you get a kick out of is a good thing:cheers: Just trying to encourage a bit of tribe / loyalties thing :(
TE37's doofus.  :P
Shoulda kept it
which doesnt disprove the fact that STOCK R32 RIMS look shit in black on a black car.
HAHA
awesome where and when??
The next calder night...want to stay away from Morwell. I cant punt a car sideways and wall are too close and too narrow and Morwell. So Calder seems the better bet at this stage:)
And i think a graphite colour with the std wheels looks bets. Black too dark, and white doesnt suit the style of the wheel. Or just spend the money on some King/Whitelien springs and the thin will look just fine and handle a bit better:)
ahhh i seee, thanks sam.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
