oh yeah... so it does!
Thanks man...
so on the list i now have...
Vertex body kit
GTR bonnet
HKS turbo
HKS Coilovers
HKS PowerFlow pod
Greddy intercooler
Apexi AVCR Boost Controller
ECU (some kind)
2 way LSD
7 Point cage
Front and rear strut brace
Bride Brick seat
ajustable fuel pressure regulator
water temp sensor
Momo 'Race' steering wheel
momo pedals
Defi Guages
Drift handbrake
hmm what else!
please have a stroker kit :(
awesome lookin 32, has definately seen some serious drift action.
check out all the cues - drift handbrake, tape around steering wheel, bride bucket, engine setup, lsd, and most importantly the cage.
reckon you might have a bit of work to do once it gets here! good luck mate
only about 10 days to go now... if the approval comes back.. was lodged on the 1st march.
can someone tell me what size wheels i can fit on? and if the guards were rolled? and if they were pumped? not forgetting this car has to be 100mm off the ground :rofl:
thanks...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
