*UPDATE*
Alright. I decided if I am getting one, I am gonna get the GREDDY V-SPL, unless it's more difficult to fit.
Has anyone fitted one of these to a R32 GTST? I am curious how easily they go in (need to cut bar/fan?)
/End Update
Gday Guys,
I am just trying to decide which intercooler kit I should get.
What is the realistic difference between them? Is it really going to matter on a 32 gtst that will never see 200RKW? I am guessing I might get it to like 170 but I won't ever go to 200. Just to give you an idea.
The options I am looking at.
ARC (From NissanSilvia.com sponsor)
M073 500x260x70 Core
- Cross Flow Piping
- Hoses
- Brackets
- Everything required to install
Price - $1300 Shipped (may have to pay $200 tax, but doubtful)
Greddy (Fron Nengun)
R-SPL 192 x 250 x 119mm, $ 1,108.99
R SPL-HG 240 x 600 x 76mm $ 1,384.76
V-SPL 276 x 600 x 76mm, $ 1,140.87
Hybrid...well i havnt seriously looked...but around the $1000? mark
What do you think is the best buy? Can someone tell me the difference in the V-SPL and the R-SPL?
Thanks guys
Chris
Look on the websit of Nungun it tells you what the difference between the R & the V is...
Hybrid are decent with bar and plate cores most of them. If your not going past 200rwkw then I think that some of the above especially the ARC one is a bit over the top..then again it may add to resale...
Hybrid will be cheaper, check out the group buys on here there is always a good deal
Thanks, I read about the difference in the V/R-SPL on the site, but what does it mean comparative to my needs. I mean, it says the V-SPL is for low boost or whatever, so what is defined as low boost? Basically which would best suit my needs. And if the hybrid is good enough, is there any point going to the greddy/arc. I mean it's only an extra $1-300 ...
the greedy v-spl will more than suit what your looking for. Personally, i'd go the jap brand but thats just me as i like the reassurance of knowing i have a japanese intercooler on a japanese car by a respected aftermarket parts company. (they would obviously know what they are doing when making parts). Price is great if you buy from nengun. I have one of these and it is great.
I cant really comment on the hybrid coolers too much except to say some people say they stink, others say you get what you pay for but then there are many people who use them and they work very well. A friend if mine with an s14a has one on his car and it sees 190rwkw and it works a treat.
Maybe ask your mechanic as well before you make a decision...
170 rwkw - Cheapest option.
Hybrid.
that doesn't mean they are crap.
they are cheap.
there are people with well over 250rwkw with those coolers.
ARC is some damn good quality stuff though.. but I can't justify that much money for a heat exchange.
Alternatively, GET a R33 gtr cooler and get custom pipes made up.
That will be my option for my next car.. if it doesn't already have FMIC..
Trust SAU people before a mechanic. I have only had 1 good experience with a workshop.
I have asked around the people I know, and they seem to reckon the ARC would be kewl (image) but the Greddy VSPL will do fine up to around 250RWKW, which is far out of my reach with my budget.
I think for the extra $100 I'd go greddy over the hybrid, purely for the name, knowing it will be quality.
The ARC I have my doubts as it's a new trader, so not too much feedback on him ATM.
Looks like the Greddy is the go.
I went to the only place I trust around my area, and they want $1300 for mild steel, $1800 for stainless for the piping, and they want $1300 for the intercooler (brand was iceblue...or icecold...or something like that)
Stupid thing is my mate had his 180 piped up with stainless for about $600ish at the same place. Surely the 32's arent THAT different!
So they can keep it, I'll get a brand name kit for much less thanks very much!
Although buying a cooler off the forum or custom made may be the cheap way out (not to hang sh!t on anyone) but you cannot be garuanteed that the cooler is of top quality.
For an example a friend of mine had a custom made 240 x 600 x 76mm cooler and it was good for letting off some cool sounding cooler noises :( but it was not pressurised correctly, it would peak at 15psi then drop to 10psi higher in the rev range.
And sure you may be able to purchase a custom made for say $300 then piping $350 - $400 (I was quoted for an R33) then by the time you buy the appropriate brackets/clamps/silicon hoses there goes another $150 if not more.
You do the math on that, but I'd much rather the assurance of buying a japanese made cooler that comes with everything to bolt straight in. Personally I am looking at a Greddy V-SPL from Nengun also and I was told the kit even comes with a stencil to cut out the hole for the left hand side piping. Now that tells you they have put thought into exactly what a purchaser wants!
My 2 cents
yep GTR...for value.
If new I'd go GREDDY/TRUST. Its what's inside that counts. Hybrid have dense truck core type internals, Trust have a cerated H shape which increases surface area without causing resriction. This gives less boost drop and more flow.
Also another think I have learnt...a slight overkill is always better because the power you have is never enough.
I'll say what I always seem to say - have you considered an R34 GTT cooler? Will be more than adequate for your needs (:)
You will need to modify the stock piping slightly to make it fit, but not too hard.
yup, get a GTR and makes the radiator hotter
GTT cooler should end up $4 - 500 cheaper plus do the job (170rwkw),
but u don't have a "FMIC" which looks many many times better :)
GTR cooler will be my pick if u will getting close to 200
if u really want a new FMIC kit
Someone in NS.com done some testing with a whole range of coolers - (include trust, hybrid..etc)
Test is about the pressure dropped before and after the intercooler and the cooling effects
All of them were very close to each other.
But Blitz seems to do the best
HERE IS A LINK SHOWING CORES - Trust COOLER INTERNALS
V-spl is not a real great cooler it has no internal fins only ridges so cooling ability is far lower than R-spl and Blitz LM but flow is good.
Blitz LM & V-spl are in the same price range but LM design is far superior. it equal to the R-spl which is 1 price range over.
GTR cooler is a good cheap option if your thinking of doing the piping yourself, ARC have been around for many years in Japan and are well known for their CAI, intercoolers, radiators. they are made by hand and fit perfect no modifications or cutting of the front bar needed. Greddy also good if you like that polished finish, good value for money. Hybrid is a mass produced item made in china, major flaw is the quality of hybrid piping
I have a genuine Hybrid r33 gtst kit
Has been on the car for over 18 months
The piping finish is a problem
When they advertise "polished piping" what they forget to say it is chrome plated alloy piping which flakes off after about 6 months. Looks like crap.
If you are after a complete kit for $1000 try uniquie autosports, they now have $999 kits to suit all cars, with australian made mandral bent alloy piping and chinese coolers
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
