Well, short-list. DR30 wouldn't been nice, but I don't think the guys would understand. A shame, since old-school Skylines are horn.
1. Flite (R32 GT-R)
2. magic1 (R33 w/ 'gate)
3. R33_Cam (R34 GT-t)
4. sileighty (obvious)
5. 13_devil (R33 GTS-t)
6. BoOsTeD_RB26 (R32 GT-R)
7. Sneaker (R32 GT-R)
Cheers to the others who offered their cars for the cause. Shame we don't have more people, but I'm trying hard enough to keep it hush-hush at school.
Just need to see how much ($$) you guys think would be fair for a lift there and one back, though we probably won't need as many cars on the way back if some of you can't make it at the midnight finish for the ball. Can just pile into the back of cars, 'cause the exit doesn't matter as much. Lest someone is up for leaving a pair of marks on the blacktop outside the Sheraton, of course!
  • Replies 73
its cool Matt, i understand :)
it's tough to like a skyline as old as mine (and not many do) but when i go out cruisin' with my mates' S15s, civics, R33s, integras etc etc it does surprise them a bit. but it's not 'suit'ed for a ball (excuse the pun)...
post some pics of it aye...
Bah, can't believe I missed a GT-R. Went through from the start of the thread to the end, thinking I'd nabbed all the GT-R's; damn! Well, if you're still in your corner, we've got another who'd like to come along. Makes a grand total of eight, 7 cars from here, one from outside.
Short-list updated
Planning to PM each of you in the next week or so, to organise times, swap contact details and find out who wants what ($$).
Well, I feel like you at least deserve something for your time, 'specially since you did it for nothing last year. Anyway, cheers Paul. How many rwkW/hp is the car pushing?
not sure. last time it was tuned it was 220hp but i have played with the safc since then and all i get is big backfires and it feels a little less sluggish.
Wow, what a cool way to show up to ur ball... 8 skylines.. nice..
My sisters yr 12 ball is this weekend... she had trouble getting a limo (all taken up). I said that i should beable to gather a few skylines for her... but she ended up getting a limo some how. Gez... I would deffently choose the gtr over a limo.. but thats me... my sis isnt as much as a rev head as me, maby cos shes blonde and im a red head??
Have fun at ur ball elithrar :(
Well, seems mikey has disappeared off the face of the earth, so I'm one car down, and still waiting for Flite (R32 GT-R) to respond. In any case, is there anyone up for filling in for Mikey?
well matt just go back thru tha thread plenty of offers most jus us crappy 33s tho i still willing ta do wine red 33 gtst for fuel and a brewsky or two afta if yas get desperate nuff
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
