  • Replies 473
/me bitch slaps Moanie upside down  :headspin:
ummm.....okaayy then...
see look what you done mike...you get strange guys who have no fu(ken idea who mona is wanting to bitch slap her......
ITS ALL YOUR FAULT MIKE !!
:rofl:
doodz: Im not just saying this cause mona is a girl (well most days she is :)) but you should talk to people on the forums and get to know them a little before making comments like that about ANYONE...guy or girl.
Yeah,
Only I can Jaw off like that..... And only because I am in QLD at the Moment.....I would't dare do it in front of Mona, She would Kick my A$$ like a cheap drunk!!!
Mike
:rofl:
exactly
get to know her then talk
/me bitch slaps moaner upside tha head
what is it with ppl getting drunk and saying somthing on sau then comming back and saying sorry cos they wernt really drunk, but realised that they sounded like a complete ass!!
btw.. /me slaps moonie upside the head wit a side of BEEF!
hmmmm me think what else we can use to slap moaner with
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
    • I'm not 100% how the BMW racers do it, but I know from other brands like Merc, moving, and changing the coolers is one of the things. Like getting a transcooler out from infront of the radiator to out near a wheel arch. So some of the stuff you've got crammed in the middle front, spread it out and open up where you can in the bar to get more air in to the sides.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
