Hey everyone, Im new to the forum and skyline owning, I had a TT 300ZX for a while, nice car if it didnt keep breaking down. Anyways, just wondering if you R33 owners have the ghost that locks the passenger door when you shift to 2nd gear. Im guessing its a safety thing, can anyone tell me if its normal and if there is a fuse I can pull to stop it.
Ta peeps
bigvis
https://www.sau.com.au/forums/topic/6580-r33-passenger-door-lock/
Originally posted by bigvis
Thanks people, looks like all of them do it, it is a bit annoying, especially with adult passengers who just wanna get out, but what the hey, thanks for the qik responses
hahaha Why!?? don't you stop b4 these "adult" passengers get out???
Or is it a 19km/h tuck and roll ??
Donnie :)
its 20klms isnt it??
sorry to be annoying but its actually 25km
and yes it can be disabled, i think its kind of cool though...
in my car ive set it up so both doors automatically lock when you turn the car on and when you turn it off they both unlock.
Oooer.... How you do that??
surely mine isnt the only line with the unlock switch by the drivers window controls?!! :D For those of you who find the auto door lock annoying, do you actually use this switch, or do you let your passengers fumble around trying to unlock their door themselves??! :shake:
i used to use it...
u dont want non familiar skyline people touching your shit! messing around with your pride and joy.
after installing my alarm my door also does that. turn on engine, it will both locks and turn off engine it will both unlocks.
if for some reason the passenger is unlocked, like someone getting off, then it will lock itself again when I drive over 20km/h.
I like this feature for security purpose.
Wow, seems heaps of people have lots to say. I find that when I stop, I open my door (sometimes im even out of the car) and then find the passenger trying to fumble with the lock...its not usual to get in the passenger side of a car, not lock the door then arrive to have it locked. I just think its annoying even with the driver side control lever thing...i guess it just being new to it, but my 300zx didnt do it. Thanks again people for answering my query so quick
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
