When we were at Eastern Creek last Thur, Red900ss was kind enough to bring along a pyrometer (tyre temp measurer)
Results after a couple of quick laps were:
Outside Middle Inside
LF: 50 50 58
LR: 58 58 66
RF: 60 59 60
RR: 60 60 59.
So all pretty consistent except for LF and LR's inside temps.
I ended up getting a wheel alignment today, and it turns out that after a certain high-speed / side on / kitty litter incident, the alignment was significantly out. In fact Toe In for left front was +6mm, and left rear was +12mm. To put that in context, a more normal figure is neutral to +1mm.
I guess my point is, get a decent wheel alignment done regularly. Improves performance, and in the case of toe in problems like this, also big impact on tyre wear.
https://www.sau.com.au/forums/topic/6596-wheel-alignment/
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
