  • Replies 66
I know you guys are eager.
So am I.
I have a Stock R34 Turbo here which I am highflowing and I'm dying to get these damn dut finished, but it seems that everywhere I turn, I run into obstacles.
I'll get there really soon.
I promise.
I have to, my next project is going to be wing mounts or Master Cylinder Braces!!
.OKAY NEWS TIME.
I have recieved word that the R33 prototype is complete!!
I will be getting it at the meeting on Tuesday night and so right after that I will be taking it to a fabricator who will make the bulk amounts. I will know then what the final price will be for the R33s. I would assume that the R34s will be the same price.
Looking good.
BASS OUT
Bass
Not being rude or anything but whats the go??? Its been nearly 6 months since your first post. If you dont want to do it just say so, because i will take it over.
Actually if i can get my hands on one, i might start one.
Hi Robo.
I know this has taken quite a while to get together, and I realise that it has probably pissed some people off, but at every corner, I have met with problems.
We have made up a jig to weld the R33 ducts together, and within 2 weeks the work will begin.
We have also worked out a price for the R33s.
$100 for the duct.
This includes the duct in Stainless Steel, mandrel bends, two welds and two 1 inch beads on each end of the duct to make sure it doesn't slide off the rubber.
SO.
I will require full payments before we manufacture the ducts so later today I will post up some details for the payments.
Nothing will go ahead until everyone is paid, as I don't want to be left with a bunch of ducts and no money for them
Hey Bass - these sound good
Ill give you $50 for one
BAHAHA - just kidding - a light hearted reference to your thread regarding people making offers pissing u off :wassup:
Anyways - put me down for an R34 for my Neo6 Stagea if they're gonna be around the same $100 mark as the R33's... but lol where's your priorities - doin R33 model before your own R34 ones!?
Cheers mate
Adam
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
