Yeah, im mistaken.  GTRS is for SR engines so at this stage, if i can get the details for the garrett equivalent for the HKSGT2835 Pro S (0.68 A/R)
3LITE FORC3 - What's your price for the garrett equivalent for HKS 2835 Pro-S? (inc. oil lines, etc.)
  • Replies 288
OK, 1 x Garrett GT30R 0.82 Ex A/R Rated at 600hp has now arrived. Stuffs me why the others aren't in yet but I am still waiting. GT25/35's are on the shelf. So are GT25's rated at 350 and 400 hp. A whole range of T3 flanged turbos are to be released soon which I am also keen to see.
Answering the question above, The HKS GT28/35 Pro-S is a GT28 Turbine with a GT35 Compressor (52 trim). I'll find out tomorrow what code and price. None of these turbos come with oil and water lines. If you want oil and water lines....buy a HKS. I can't buy the kits seperate. You are only looking at around $200 to get braided lines made up anyway. As long as the manifold flange is the same style.
Daniel,
I need a turbo with 0.70 compressor and 0.82 turbine, internally wastegated, rated at around 700hp.
I was looking at the GT35/40R but I think it only comes in a 1.06 turbine internally gated.
Car is the R33GTST hiflow injectors, intercooler, fuel pressure regulator, Z32 airflow meter, Power FC etc.
Currently have a Hiflow but can only get 302hp aiming for 400+hp at the wheels
Cheers Dave
Answering the question above, The HKS GT28/35 Pro-S is a GT28 Turbine with a GT35 Compressor (52 trim). I'll find out tomorrow what code and price. None of these turbos come with oil and water lines. As long as the manifold flange is the same style.
Thanks.. post the price here when you have the details.
:D
Daniel,
 Cheers Dave
I am yet to see a turbo that is rated at 700hp that is internally wastegated. They don't have wastegates big enough and even if you could get one made, you would suffer boost creep something major. The fact is...if you want a turbo rated at 700 hp...you need to have external gate. I can probably get something made in internal gate but it will be totally useless.
The GT35/40R 0.70 / 1.06 int wastegated is rated at 700hp according to the Garret catalog.
Can you source best price for external waste ates?? Whats the best turbo with 0.70 compressor / 0.82 turbine? Has to be rated at least 700hp to get the 400hp at the wheels!
Yes, I can get a T04B but I'll have to check on a price for you tomorrow.
No I can't get highmount manifolds or external wastegates...well I can but for not much cheaper than you can. Normal trade discount for things like that. Talk to Slide if you want manifolds or wastegates or visit his website.
How much horsepower/kilowatts do you want? eg. 380rwhp/280rwkw
What are you using the car for? eg. 80% street 20% Drag
When do you want boost roughly? around 1 bar at 3800rpm
Do you want power early or late in the rev? range nice low down, but strong midrange and top end
What Mods you engine has or is going to have including computers or exhaust? 3 " exhaust G-Reddy Computer, 600x300x80 Cooler, Cam Gears, AVCR, fuel pump, injectors, malpassi, all the usuals
Obviously, what car? Toyota Chaser with a 1jz-gte
Still running AFM or upgraded or no longer there? never had one
Custom exhaust manifold or standard?Custom Exhaust Manifold
External wastegate or internal? External
I was thinking a 600hp GT30 with a .82 rear housing from what people and info i have read tell me. What you reckon and what price
Just a question about the 2530...
what flange do they normally come with ? cos i heard they normally come with T2 but sometimes come with T3. Anyway i assume these come with T2 so i just have to buy an adapter kit to make it T3 is that correct ?
any ideas where i can get just the kit, cos your price for the 2530 (I know you still have to confirm) is really good but i have no idea how much a kit costs
I'd reckon you are spot on. Prices for them change almost daily depending on how many he is buying but $1900-$2000 for the GT30R with 0.82 A/R. BTW good choice. They have one on the shelf ready to go I believe.
Yes that is correct. The 2530 is a T2 foot but I think you are still able to get it in a T3. I will see if I can find out tomorrow for you. If not, you would need an adapter plate made to suit it or get a custom manifold. The adapter plate a fairly easy to do but you would have to supply the manifold so that I can have it done for you. I don't know exactly how much it would cost but I can find out.
:P
Still waiting for the price....
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
