Uhm.. I had a little accident in the car. :Oops:
I was driving on my merry way back to work after getting subway for lunch when i braked a little hardish for my drinks liking and it decided to spill everywhere! :rofl:
So I now have a swimming pool of coke and creaming soda on my drivers side floor and stickiness to my centre console and gearstick boot.
So can anyone recommend a carpet cleaner that can get rid of coke in the carpet and a bit on the seats?
https://www.sau.com.au/forums/topic/66373-carpet-cleaner/
:uhh:
I've parked it out the front of work with the windows down at the moment to try and dry it up. Is this a bad thing? I've also got paper towel down trying to soak it up... Hrm.. I might get andrew to go to Aussie Auto now and get something and I'll do it when I get home and leave it over night to work it's magic :rofl:
https://www.sau.com.au/forums/topic/66373-carpet-cleaner/#findComment-1236624
Use a damp sponge to wet and soak it up.
This will dilute the spill and remove as much residue as possible.
Don't use a hair dryer or heater or any artificial method of drying, this could damage your carpet.
The carpet in a lot of cars (not 100% sure for Skylines) can contain acrylic and artificial fibres which can melt really easy!
Open door and leave in the sun.
If still sticky
repeat.
https://www.sau.com.au/forums/topic/66373-carpet-cleaner/#findComment-1236676
Well I got andrew to grab some stuffs from Aussie Auto on the way down and he bought some Meguires stuff and some other thing cause it had a cool brush on the lid. :)
Luckily when I got home it was still wet so we just sprayed the stuff on it and cleaned it and left the windows down to dry it. While the car was at work, I placed some paper towel down to try and soak up some of it. It kinda worked :S
Thanks anyway guys.. now I just have to get the splash marks off my centre console, avcr, steering wheel, handbrake, gearstick, dask. :)
Never EVER taking that drink in my car again!
https://www.sau.com.au/forums/topic/66373-carpet-cleaner/#findComment-1237197
Can you sell me some of this... "AMWAY"... Bob?
I know where you can get it...unfortunately I cannot arrange until my return...sorry.
I swear by this stuff...and not any carpet cleaner will do (geez does that sound like a ****in cheezy sales pitch)...
I am sure you could look up Amway and thye would direct you to someone...
https://www.sau.com.au/forums/topic/66373-carpet-cleaner/#findComment-1237198
Yeah I had same prob in my last car with a mcdonalds drink....it's those stupid lids, if it tips over for any reason (esp. if it hits the floor) it's everywhere. Now I only take ones with screw on caps.
yea coke from maccas has done it to me before.....the centre console "drink holder" is to large for a large coke dammit....but yea its never posed a large problem always cleaned up ok
https://www.sau.com.au/forums/topic/66373-carpet-cleaner/#findComment-1237572
Strangely enough Spray and Wipe is great for home carpet stains and spills, I ahve also used it to remove stains from an older car..
I once left an Iced Coffe full on the back seat of my 180, a few days later, (I live in the Pilbar it was like 40 every day) I came ack to my car and the back seat had soaked up all the off milk, was one of the most disgusting smells that I have ever experienced. Took weeks to get the smell out, and basically once the smell was gone, a week later the car was smashed, poor car..
https://www.sau.com.au/forums/topic/66373-carpet-cleaner/#findComment-1237652
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
