Hey PVA was that you tail gating me the red pulsar yesterday about 6 ish in South Perth? Big SDU stickers on a grey line.
Anyhow is that also your car on the road running adjacent to the Freeway with the busted rear drivers side window? Man that car looks worse for wear.
And another thing spot trying to rear end mate the uslar dude.:shake:
https://www.sau.com.au/forums/topic/6641-pva-spotted/
Ummm it could been me I was going to some's house...
I was around south perth area...:D
I did Dragged the new VW Golf or some thing.... I WON heheh :D
only by one car length..he was reving hard and wheel spin...
but NA skyline is still faster! :D
and now I am back at work from court! ehheh I WON :D
cheers
Joe
https://www.sau.com.au/forums/topic/6641-pva-spotted/#findComment-98812
Originally posted by G0DF4Th3R
hah if u guys see a black Skyline with the registration 1BBI-355 let me know coz im in Malaysia now and the car is with a friend and wanna make sure he doesnt push my baby too hard... :D
hey man is yours the series 2 with chrome two piece rims?
https://www.sau.com.au/forums/topic/6641-pva-spotted/#findComment-98908
I have officially stopped letting mates drive my car. She buckled a rim on me old Soarer... bah women drivers my butt.
What are you doin man?!?
You can't let a chick drive your car! I let one drive my old lancer and instead of goin around a round-a-bout she decided to go over it.
No one but myself has driven my 'Line. Except for my tuners.
https://www.sau.com.au/forums/topic/6641-pva-spotted/#findComment-98931
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
