Well see the post about Autosalon for show/n/shine
We don't drift, but normally a pack of us head out to watch the Mallala drift days
We have only had one track day and will have another near the end of winter this year (with any sort of luck) - after we get oil coolers (since last time we went out an engine was blown due to oil temp/starvation, a turbo fried from the same, and my oil temp went through 230 degrees)
But mostly we just hang out and cruise occasionally. Not a particularly active club I'm afraid, but we do get together for a dinner every 3 months or so. Unfortunately the aggressive activites and tactics from the cops has put most of us on the back foot and cruises have dried up lately. Last cruise I went on the cops blocked off the 2 entrances to the carpark about 150 cars were occupying on a stop, and proceeded to thoroughly check every car and issue a huge pile of defect notices. This wasn't an SAU cruise, but was attaneded by quite a few SAU people.
Just keep checking this forum for events in general
https://www.sau.com.au/forums/topic/66433-upcoming-events/#findComment-1237802
yep I vote Guy to organise it - as it seems I am so crap at organising events :P - and yes, definitely no 1st weekend of April, as that is the big Victor Harbour cruise and Go-Karting!!!
I remember the old House of Khans on Montague Rd - great food .... is this place the same - you pick your ingredients and flavouring/spices then they cook it on a big round plate in front of you? Yummmmmmmmmmmmmm! I haven't been to Gengis Khan for ages also, so looking forward to this if its the same.
https://www.sau.com.au/forums/topic/66433-upcoming-events/#findComment-1241898
  • 3 weeks later...
Not really, no curry here.
I have organised a price of $20 per person for the banquet. Normally its $22.50.
The days available are Sunday through to Thursday night.
If we get more than 6 people maybe we can get it down to $19.
And a few jugs of softdrink on the house for the SAU table worth $6.50 each.
Not its just a matter to choose a date that everyone is cool with.
Will
https://www.sau.com.au/forums/topic/66433-upcoming-events/#findComment-1267619
sorry to sound like a jessica simpson, but is mongolian similar to indian?
Its a bit like a BBQ/stir fry - but the contents are selected by you.
Last time I went all the basic ingredients are prepared in separate bays, (pre cut and ready to cook) and you pick out the bits you want (i.e. beef, chicken, carrots, cabbage, etc, etc) you then add the sauces you want (can be hot and spicy through to mild and sweet)
Take it over to the cooks who cook it on a great big shield/hot plate and your done. For cops like me a benefit is that you can go back again and again and again and try all kinds of combinations.
https://www.sau.com.au/forums/topic/66433-upcoming-events/#findComment-1267744
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
