Hi. Im thinking of spending $5k on my R33 GTS-t. So far it has POD, 3" zaust from turbo, 'cooler and is lowered with mags.
Any suggestion as to what to spend this $5k on? i admit i dont know much about this stuff, but was thinking maybe new turbo, injectors, fuel pump, computer etc. does anyone have any advice about this stuff? brands, sizes etc.
thanks for any help.
https://www.sau.com.au/forums/topic/66529-5k-budget/
Hey mate i have a turbo package that would suit you, its only $1000,00. Which includes turbo, waste gate, all braided lines and chrome rfittings to suit, also comes with a hks pod filter and custom turbo blanket. That would leave you with $4000 and you could get a power fc and hi flowed injectors fitted and tuned for $2500. Than get a fuel pump bout $400 fitted and than the use the rest to set up the turbo it come with a factory warranty as well. Just a thought i can send u pics of the turbo if you like.
https://www.sau.com.au/forums/topic/66529-5k-budget/#findComment-1238258
nengun had a gtrs for rb25 kit for $4500 i think it was. powerfc, boost controller kit, gtrs turbo, injectors all fittings and gaskets etc. would be well suited. however you would still need a clutch, good tyres and a set of cams for more midrange power. the gtrs on rb25 can do around 260rwkw (ish) check out rb25 turbo upgrade thread a few months ago.
https://www.sau.com.au/forums/topic/66529-5k-budget/#findComment-1238292
I just did the gtrs $2912, 6 nismo 555cc injectors $939, power fc and boost kit $1510 + $250 shipping got 270rwkw at 1.2 bar and good response. Also need z32 airflow meter $295 and dyno tune and installation. But you could do it with out the z32 and injectors and keep the boost a bit lower and keep it under 250rwkw.
https://www.sau.com.au/forums/topic/66529-5k-budget/#findComment-1239876
I just did the gtrs $2912, 6 nismo 555cc injectors $939, power fc and boost kit $1510 + $250 shipping got 270rwkw at 1.2 bar and good response. Also need z32 airflow meter $295 and dyno tune and installation. But you could do it with out the z32 and injectors and keep the boost a bit lower and keep it under 250rwkw and do the rest later.
https://www.sau.com.au/forums/topic/66529-5k-budget/#findComment-1239881
HD Clutch =$1200 installed
exhaust side adjustable cam gear - $250 installed
PFC + boost controller kit= $1500 + fitted & tune ($400)
Borch Fuel Pump $350 installed
gcg BB high flow - 1800 installed
220rwkw should not be a problem
once u got the $$ for injector and head gasket 250+ is achivable
https://www.sau.com.au/forums/topic/66529-5k-budget/#findComment-1240082
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
