Wondenrig if anyone can help me. I just got a stock 98 R34 GT-t two door. And had this banging noise in the rear suspension on the right hand side. So we hoisted it up and oils everywhere and the shocks are totally gone. The good thing is it is under warrenty so the dealership have to pay for it to be fixed. Currently looking at koni's or geniune nissan replacements. What do you guys recommend? Also seeing as i'm getting new shocks should i get new springs as well?
https://www.sau.com.au/forums/topic/66638-best-suspension-for-r34/
Late reply I know, but I only just came across your thread.
I have put Bilstein Shocks and Whiteline Springs on my 2001 R34GTX-T. It corners like on rails now. Don't forget to get the camber kit too. This could stop you scrubbing your tyres prematurely.
Hope this helps.
How much did the bilsteins cost you? And do i only need the camber kit if i get lower springs? Thanks
Hope this helps.
I'm sure prices will vary state to state, but from my research I managed to pick them up locally for just over $1k for front and rear shocks.
As for the camber kit, 34's already have a fairly aggressive rear camber as stock, so I thought it was piece of mind to buy 2 kits to bring it to negative 1 camber. My thoughts were $120 bucks for 2 kits is cheaper than buying two new tyres.
I have never looked back. Having said all this, you haven't mentioned what you intend on doing with the car; daily driver, weekend track work or drift?
Mostly daily driver and going through the Adelaide hills on weekends.
Turns out though the dealer will only allow me to get stock nissan suspension put back on it and i have to get it done at a dealer that he choses. So i'm getting it done this thursday at Souther Motors Victor Harbor and they are just using genuine nissan replacement shocks, but thats ok it's better than having shagged suspension and now i can always save up for better ones in the future. Thanks for all the feedback guys and girls.
Where did you get the bilsteins from?
Did you have any dramas with 2 door and 4 door differences?
There's so much bum info out there on R34's and particularly R34 4 doors.
Whiteline have told me they can't get ANY shocks to fit the rear of my car.
Thanks.
i also have HA teins on mine and i have to say best handling ive even had and no scrub either..
i have had a few people drive it as well and they all want there car to handle the same
but i believe teins are more for track than road but up to you really...
i have heard very good things about bilsteins cornering and the rest they are considered to be pretty much the best but also that comes to personal perference.
Hi Adam.
Technically Whiteline are correct. Bilstein have not made a shock specifically for the R34. But you can get the R33 GTST fronts and the R33 GTR rears (fork Type) to suit the R34.
There was no notable difference betweeen the 2 and 4 door. The whitleine springs worked a treat. The only thing that took a little extra time to fit was the rear springs as they had to be compressed first to be able to fit them. This is because the R33GTR rear shocks are slightly shorter, but the car still sits well and handles extremely well.
I will get some pics posted so you can see how it sits.
Whiteline can sell you the shocks but I bought my shocks from http://www.gsad.com.au/ as they were local and a little cheaper.
The part numbers FYI for the Bilstein shocks are
FRONT> F4-B46-1873-10
REAR> F4-B46-2108-H0
Thanks.
You forgot to mention that you have a nismo rear stabiliser bar + 245F and 265R tyres on :ufo:
hahhaah, bit of a whiteline fan i see :P
I think for the limited track time i'll be doing, the Bilstein and Whiteline Springs seems to be the go. So that would be the handling AND sports packs yeah?
What u running Bass?
cheers
cool, thanks for that.
How do you find ur setup with the Koni's and Whiteline springs?
I know that Whiteline revalve their shocks, so they may start out as Bilstein or Koni's, etc... do u get all ur stuff as part of a whiteline pack? U running all the other stuff as well, from the handling pack?
aren't coil-overs a bit harsh for our roads?
cheers,
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
