To many who question why so many new cars no longer come with a turbo engine in Japan. Simple answer behind that is, manufacturers don't need to spend the extra R&D money on the engine when there are so many tuning shops in Japan who will happily tune an MX-5, 350Z etc.  Manufacturers know owner's/enthusiasts who really wants to tune a beast will be willing to spend the extra after...and would rather take the car to a specialised tuning shop with years of experience.
I thought it was more along the lines of that turbos are very emmision unfriendly.. and that alot of the 'general public' arent a particular fan of em..
  • Replies 45
I thought we already knew that, however if a turbo engine were so important to a manufacturer's specific model line up they wouldn't have given up so easily.
wrx and evo are still turbo so i dont think its emmisions
its not being turbo thats the problem, its the design of the engine and ecu.
anyways, the mx5 would be mint if it had a famila gtr engine plugged in, they are pretty much the exact same physical size. One of these engines gave me 200hp at all 4 wheels. so in a mx5 it should be sweet!!
steve
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
