I know how you guys like pictures :cheers:
The blue one is the hydraulic profile I grind on and the red one is your GTR cam. This graph is what is on the camshaft. You can see what needs to be taken off. The little closing ramp on the blue one demonstrates a very good hydraulic profile made by nissan to prevent fast valve seating and potentially necking the valves.
This one is to give you an idea of what happens at the valve. The red (GTR) profile is smaller because it has had some clearance taken off it. So you can see the gains to be had from this grind. I don't have a GTS grind on the cam doctor (or couldn't be stuffed finding it) but rest assured it is quite a bit smaller again.
Ivan Tighe Engineering
47 Westgate St
Wacol. 4076 Q.
Put a note in there saying what you want along with your details and attention it to me. (Just a general rule for anyonw who wants to do it)
is that near st lucia? 4076 was my new postcode i thought...
Luke, I've been slack and not on for a couple of days but will hopefully get them away today.
Ivan Tighe's huh, had some cam work done there before when it was near the city. Very impressed with the rep and the work done.
As for Qld, give me ummm ......3.5 months and Vic can go to hell, or antarctica, whichever is closest. ;)
    • I've got a spare standard box sitting in the garage  I know it will come one day though, but it's driven pretty tamely on the four times a year it gets out...
    • Big question… have you decided on a gearbox? Because it’s going to come… and a gearset ain’t going to do the job.    save your pennies 🤪
    • it was good to see our presence at GTR festival..hope to see more SAU at these events
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
