Funky - thanks but I found one at work. Its a male DB25 -> female DB9 but I'll just have to figure out the pins and wire it stright in, otherwise I think I have a DB9-DB25 converter at home. Otherwise I'll get one off a mate who reckons he might have one laying around at home. I had some but threw them all out about 6 months ago, thought I'd never need a serial cable again! :P
Might build the IEBC tonight too.. :(
  • Replies 218
dont rely on this, as the kit probably (almost definitely) doesnt use just the 2 or 3 pins rs232 often uses, but all of them. if they only needed 9 pins or less theyd use the db9 in first place
cameron, should be in the mail now. Give it till monday depending on where you live?
Thanks for that NewKleer, I'd actually thought of that earlier today ;) It's logical! I found a DB25-DB9 at work today and a DB25 printer cable, and cut up that one. I cut off the printer plug end, then went through pin by pin working out what wire ran to what pin. So then I just soldered the wires onto the HC board where the respective pins would go (ie. pin 2 to pin 2, etc).
Then I applied some power, plugged it all in and it's all good! HC lit up in its green goodness and nothing appeared on the screen, so I just adjusted the contrast up a bit and text appeared :rofl:
Anyway cut a long story short, I've tested it fully and calibrated it so it's ready to go in my 180. I've also printed out the pinout for my ECU, so I might stick it in tomorrow night. But I cant wait! *thinks* 2 hours till bedtime, hrm I might go have a play :D
(BTW, funky if all my posts should be in SydneyKid's thread (rather than a group buy thread), move em over (you're a admin right?)) :)
Here's photos of the finish(ing)(ed) DFA/HC:
Hi Shan,
I'm registering interest for the group buy for the following items:
1x Independant Electronic Boost Controller
1x Hand Controller
1x Cable
Which should be $151.80 including GST if I'm remember correctly. If you want I'll just make it a square $155 for your help in organising the buy and helping us out. Unless I also need to take postage into account? If thats the does $160 for all those items posted sound good?
Anyways hit me up with a PM or call me on 0403578014 when you've got enough numbers for the group buy. I might have 1 or 2 friends interested in everything above except for the DFA.
Cheers and thanks,
Andy
Hi again Shan,
Just thought I'd let you know that I've confirmed that my friends are also interested. So thats now 1xDFA, 1xHC and 2xCable extra ontop of my oder. Can you tell me how close we are to the second group buy? Or maybe you could start a new thread and list all the interested people?
Would just like this soon thats all. :P
Cheers,
Andy
Well I got the DFA installed last night but my car was running like a POS, but that was because I took off my AFM the other day and I think (well, now know for sure) that the electrical connections were a bit crappy because of lots of steering fluid over the connector (I have a leak in the pwr steer pressure line). So tonight I cleaned it all up and reset the DFA (and my ECU) and went out driv.. err...tuning. :) After driving around for about an hour and a half, down to Clayton (uni) and back, it's noticeably different. I don't have an air/fuel ratio meter nor my multimeter hooked up to the O2 sensor, so I was just guessing and going by the 'feel' and sound of the car. It certainly feels more responsive and harder coming onto boost. And driving on the freeway, my (loud) exhaust is quieter because I don't seem to have my foot as far down on the accelerator. I know because if I turn on my air con, I have to accelerate more on the freeway and my exhaust becomes louder. This is the opposite.
I'm happy with it:) I just need to build some kind of air/fuel meter and Jaycar/SC have a few projects of the like. Or I could just jam my multimeter on the O2 signal to watch the voltage but with the update rate of it, it might not help much. But yeah, no more burbling when slowing down in gear with 2k-3k revs :) Andddd no more backfiring when totally booting it after changing gears; well sometimes it does but its not as bad I don't think :)
Next up I'll build the IEBC, but I'm not in a hurry because I'm awaiting a Greddy boost gauge from Nengun in the mail. :)
does any one know where i can get the r33 rb25 det ecu pins? I can't find it. I finished building the IEBC and handcontroller. I used the 12v that goes to the head unit to test. Was very happy when the screen lit up. I think i'll use that as the power as i don't want to chop the ecu wires too much.
edit: How much for the digital thermometer. I might be up for 2 or 3 of them oil and water temp and 1 for me bro :)
getrippedoff, I think you guys do have enough for a second buy... Just wait till Tuesday when the last orders have reached their owners and then I'll get started on group buy #2 on a new thread.
BTW I have tracking numbers for the packages I sent out in the office, I'll PM them to you guys when I get in tomorrow.
edit: How much for the digital thermometer. I might be up for 2 or 3 of them oil and water temp and 1 for me bro :rofl:
For those making these kits, the APEXi AVCR/SAFC2 wiring instructions might be very handy. I used the SAFC2 instructions to find the pins on my SR20DET ECU for the DFA because it uses the same ECU pins (AFM + power + GND). It looks like the AVCR instructions show the #1 injector input also so that might help with the IEBC. The instructions have ECU pinouts (well, only the pins you're concerned with when installing a AVCR/SAFC) for almost every Japanese car around.
They are on the APEXi website at:
AVCR: http://www.apexi-usa.com/productdocumentat..._savcr_wire.pdf
SAFC2: http://www.apexi-usa.com/productdocumentat.../AFC2Wiring.pdf
I'd also gotten some doccos from a quick Google search which included wire colours and stuff which was good for the verification that I was looking at the right wires. Try a Google/Yahoo/etc search for 'ecu pinout r33' or something. :cheers:
man ... i think my iebc doesnt work ..has power.. injector signal ..and a soliniod.. but nothing .....dunno what i did wrong putting them together.. but its pissing me off
Matt
yea she has power ..first pair of lights are working.. other than that ....nothing...getting my uncle to have a look at it today.. hopefully its nothing major
Matt
if u turn up the % on the hand controller the 3rd led will start to blink once you have reached 100% it will be on fully. U will see it getting brighter as you move up in the percentages.
rom.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
