I have a r32 gtr with the following mods and i was wondering what else needs to be done to get to the 350-400awkw mark.
Apexi PFC
3.5inch exhaust
Nismo 276L/H fuel pump (in tank)
Twin HKS airpods
Trust 600x300x100 fmic
Nismo fuel regulator
HKS twin plate clutch and lightweight flywheel
HKS dump pipes
HKS oil cooler
HKS Cam pulleys
N1 oil pump
N1 water pump
No cat converter
80mm AFM's (not sure what sort. Green sticker, 22680 02U00 A36-000 J60?)
Nismo LSD
N1 turbo's running 1 Bar
Anyone got any idea's how much awkw i would be making now? And what i need to reach 350-400awkw?
I was thinking a set of Tomei Poncams, HKS 2530's or GT-RS's, 800cc Inj? would that get me there?
Thnx in advance
Dave
https://www.sau.com.au/forums/topic/66963-what-mods-for-350-400awkw/
2530 will be around 330-350 on pulp. maybe a "tad" more.
fuel it up with nice stuff and then you'll get 400. and yeah, injectors come into play.
you might need to go 4"... keep that in mind for the exhaust.
if your track racing it, dont expect the motor to last long much above 350
Thnx in advance
Dave
The short answer of what you need is money and time. Unless the engine has newly refurbished and strengthened internals, expect to be up for a rebuild sooner rater than later at the power levels that you asked about.
You have what should be a well matched and balanced setup and should give decent reliability - consider if you have the cash and the patience to go to the next step.
Good luck
Gav
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
