Can somebody help me interpret this?
Things I think i know: 98 ER34 25GTT, Grade 4 (interior grade B), 80,370km, Auto, Athlete Silver in colour, auto aircond, power windows, power steer, airbag (4)
Defects: medium crack left side skirt, small crack right side skirt, small scratches right hand rear door, medium scrape left hand front bar, medium scratch bonnet
What I'm interested in knowing: any evidence of engine problems/sounds or anything bad at all (I'm making a KIPS claim), what AW means in the options, what the "special features" are for the car (box above front of car), what the positive and negative comments are (left hand side next to car) & what the writing on the windscreen means.
Thankyou!
