Sorry for posting this in the WA section but its kinda urgent and over east things are always messy :D
I have a burnt out drivers window motor and a buggered auto window switch and i was wondering if anyone had either or both as unfortunately.. my window is stuck in the down position :D
anyone able to help or tell me of a reptuable wrecker???
i am in need of help.
thanks guys
Nate
Hey nate, samething happen to me, I went to hyperdrive and ask ken who to go too, he send me to AGI cost me $50,
If i can find my old one i give it to you as it would put the window up but not down, so atlest u can drive the car around, if u want it just drop us a pm or reply in the msg
I have an R33 drivers side motor here which is a mates and got it from him to see if it would fit in the 32 but no luck as the cog on the motor is too small.
he wants $150 for it.
Shaun
if he would take $125 then i would be happy to collect asap.
thanks for your help Rad.
i had no luck with AGI :)
God Bless,
Nate
Cool, Id say its ok but ive dropped him and email and I await his reply.
The wires to the plug have been cut and soldered back together because I pulled it apart to put the motor into my R32 one. That worked but i found out it was the large plastic cog on the 32 item that had teeth missing and it was jamming. The parts from the 33 could not be removed from the unit so i couldn't use it.
The 33 unti is all back together and works fine.
Shaun
  • 3 weeks later...
yeah, i did... i have found out that it was the switch which was faulty.
The switch mech as stuck in the down posistion causing teh motor to burn out... i though that they had some sort of thermal cut-out but maybe not :D
any info would be great though Kim
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
