Just a quick one..
Thing the headgasket may possibly be gone in one of my cars. Doesn't seem to be oil, but lot of bubbles. I know one of the coolant lines is split - could this be introducing air into the radiator??
If I need to, can I replace the headgasket without removing the whole engine?
I am thinking I can just remove the head, replace the gasket, then bolt the head back in, whilst the block stays in the engine bay. Is this achieveable?
How much is a replacement nissan genuine (or close to it) RB20DET gasket these days?
Thanks.
Head gasket can be done with block still in the car no worries. Its a bitch of a job, not that its hugely difficult but it can quickly snowball when you find you have to replace things(which is a good thing really) worst part of it all is getting the exhaust manifold off without snapping bolts. good chance to do timing belt while your there
good luck, tim
I was thinking just taking off turbo and leaving the ex manifold on too to make that easier :)
Intake manifold will be fun however.
I am not too sure at this stage, as I just stuck the compression meter in a couple of cylinders and it's not massively down. Should I check all cylinders?
vrs kit for rb25det(should be similar) is $250 from nissan and yes u can do it as said before with the engine still in.
you might find a few exhaust man studs broken as well as cracks in the manifold, have a good look.
look around where the head meets the block for coolant leaks, does your coolant level drop a lot quickly?
All cylinders were around 130psi give or take 5%.. my gauge always reads about 130psi on previous engines that have been in good condition.
So will that mean it is not the head gasket? I drained a fair bit of water whilst removing the hose.. no sign of oil in there. It just foams up the top which almost looks a bit browny (although that could be a bit of rust)
I did mix coolants the other day (i know you're not *meant to*) - because the hose was leaking I just had to top it up with some other coolant lying around go get by.. could there be a chemical reaction going on between the different coolants?
There hasn't been any signs of abnormal heat in the engine or anything like that recently.
As you can see I'm almost half way there (replacing a bad water hose) underneath plenum. So if is head gasket, maybe will just leave it apart and do the whole lot.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
