okkkkkk big dramas with my car!!!!! need an idea of whats happened i thort i knew but here goes..
b4 i begin some info on my car.
its an 89 model gtst completely stock when i got it never modded with 75,000km
i have boosted her to 12psi, 3 and a half inch exhaust all the way, and a blow off
welll about the dramas, they started about 3-4 months ago? my friend was driving my car without me in it, he pulled up to a set of lights put the car in second, forgot it was in second then tried to rack it up revved her upto some rediculous amount and dumped it and rode the clutch like a bitch nigga, any way he smelt the clutch hard and then it got stuck in gear or something? then wouldnt go back into gear any ways, he pumped the clutch a few times and kinda went back to normal, she drove alright for a lil while but then one night she just started going, slipping like crazy, and could smell the clutch burning heaps, kept slipping more and more till she couldnt slip no more and couldnt get up hills and then couldnt get off any where.
now what happens, i turn her on, by touching her ignition;) :PP yurr and put her into gear but she dosnt go any where, pull the clutch out dosnt move, just sits der dosnt stall, i can change gears with out pushin in the clutch pedal asif the clutch is in?!!! and i can hear the gearbox clicking like it would normally, the clutch im guessing is the stock one from when it was made, same as the box, any one ever have anything similar happen or know whats going on? some one told me if the clutch was completely gone it wouldnt go into gear?
help pls i wanna fix it and i dun wanna do anything till i know what sure is wrong and i wanna avoid towing her around every where to get it checked out!
https://www.sau.com.au/forums/topic/67283-ok-wtf-is-wrong/
no it does go into gear, i know a bit about cars, but i havnt had that much experience, iv had a clutch slip on me b4 and shit. what happens now is it goes into gear fine even without the clutch in, too me it feels like the clutch could be stuck on? i dont think the gears are gone because it was slipping and started slipping more and more in one night and then just didnt go no more
while trying to feather her back home the car was just revving upto whatever revs and moving like a slug and slipping heaps and i could smell the clutch really bad
i leant ma car to my ex gf's bro dat day and when it came back that was what happened he reckoned it just started going and he wasnt ****ing about, his older bro also had the same story
https://www.sau.com.au/forums/topic/67283-ok-wtf-is-wrong/#findComment-1249262
Well thinking about it logically. If the clutch is no longer engaging properly, then the car may be acting as though the clutch pedal is permanently depressed. Can you roll the car with it in gear, eg try pushing it whilst in gear.
It's obviously something to do with the clutch....get it on a tow truck and take it to a reputed import garage close to where you live. Either way its going to cost some dollars to repair.
The stocko organic clutches are pretty weak....and considering the age of your car it may not have taken to kindly to a 12psi boost setting.
Grab a single plate Heavy Duty ceramic clutch to replace it or if you don't have the cash, source a stocko replacement.
Good luck mate.
https://www.sau.com.au/forums/topic/67283-ok-wtf-is-wrong/#findComment-1249263
u'll need to be more specific and clearer with your language..
but from what i can gather... it seems like your clutch is
a) gone
B) the clutch fork (?) has come loose. the thing that engages the clutch.. not sure, it happened
to a mate of mine.
https://www.sau.com.au/forums/topic/67283-ok-wtf-is-wrong/#findComment-1249267
if i can roll it while in gear what does this mean? im gonna go try
3 things
a) your clutch plate is COMPLETLY burnt out and stuffed
B) there is a problem with your clutch hydralics leaving the clutch jammed on
c) the clutch fork has half-come off the pins, and has jammed in place
check b/c by getting under the car and looking at the clutch fork/slave cylinder and see if there is any pressure on the clutch fork, with your foot NOT on the clutch there shouldnt be any "real" pressure. get someone to press the clutch pedal in the car and see if the fork/slave cylinder rod moves
my money is on (a) thou
https://www.sau.com.au/forums/topic/67283-ok-wtf-is-wrong/#findComment-1249290
if u got no fluid
when u get under the car u will find that the piston has poped out of the bore of the slave cylinder
and that the clutch fork has come loose (there is a 90% chance this happened also, ull need to pull the box to fix it)
u may think this is speculation but ull see im right when u get under the car and look
https://www.sau.com.au/forums/topic/67283-ok-wtf-is-wrong/#findComment-1249385
yeh my dad told me that the master or slave cylinder or some shit has gone, said id need a new seal? and a new clutch/pressure plate and machine of the flywheel because oil would have leaked onto my clutch
he has a front end liscence, durr :D i been fighting with him a lil and on bad terms over my car do i didnt ask before
he also said that it could be the fork popped out as u said, thx for the feed back guys really appreciate it,
and sorry about talking like a total noob:P im just a lazy ass when it comes to typing and half ass my sentences ;)
https://www.sau.com.au/forums/topic/67283-ok-wtf-is-wrong/#findComment-1249389
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
