  • Replies 83
Theres heaps of places out west .. I live in richmond and i know of some good roads.
For example we could all go up putty road and bak, maybe throu Wisemans ferry and bak along towards sprindwood road up the mountain past the lookouts and stuff, along the freeway bak down to penrith then along M4 to somewhere like homebush or something
I say go west!
No date has been decided yet, we'll work on that soon... working on a location at the moment.
So... In the lead we have:
1)
For example we could all go up putty road and bak, maybe throu Wisemans ferry and bak along towards sprindwood road up the mountain past the lookouts and stuff, along the freeway bak down to penrith then along M4 to somewhere like homebush or something ?
2)
best place i would say will have to be
Palm beach through akuna bay.
what do yaz reckon???
I've heard the roads round akuna bay are pretty crap?... Also we could do a run down the freeway and off to peats ridge?
Actually the road through Akuna bay via the marina called (Liberator General San Martin Rd) is not the best. I drive that section nearly once a week for fun with friends. However the road to West Head is an awesome drive. Unfortunately that section is now closed off at sunset.
If you really wanted to go through Akuna Bay you would need someone who knows that road and knows when to slow down when there are potholes. MOST of it is fine except the section just before the marina if you are heading east. It is a good twisty road though.
Your best bet is just to skip the Akuna Bay section and just go vai McCarrs Creek rd and then through Bayview to Newport then palm beach.
The BEST section of that whole area is coming back from Bayview through Mc Carrs Creek rd. Once you pass the intersection of McCarrs Creek rd and West Head Rd, the road is all 2nd, 3rd gear uphill tight bends.
Hope that helps guys.
Sounds like you know your stuff there man and that sounds pretty good...
can i get some more suggestions off people?
ok well it looks like they have put me on gaves next week so i'll be out for the count for next weekend. that said i also get paid next fri so 2 weeks on friday would suit me perfectly.
Liz, as for my blue passenger light.... it stops junkies shooting up in the foot well.
or we could meet at balmoral *spelling* have fish and chips for dinner then heaps up warringah road to go to palm beach, stuff round there for a while, and head somewhere else?
MYSTR33 ive never been on a cruise with this bunch so we can be loaners together... sounds ok ?
i dont mind where it is really .. im just letting some of u guys know of a path to take :)
The route i suggested is only a ruff idea and can actually venture further towards city, or beaches.
I have no idea where this other place is ill have to WHEREIS it ;)
Ill be there when ever u guys sort it out , i wont bite . RAAAAAAAAAAAAAAAAAAAAA! :)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
