Just a tid bit of info that others may be able to make use of.
Back in 2001, or was it 2002:confused: i had my master cylinder re-sleeved as it appeared to have been worn and was allowing pressure to bleed past its seals.
Fast forward to 2005 and the last two track days have meant the brake pedal has been getting progressively worse / spongier:(
So off to Race Brakes and it appears that when you have the master cylinder re-sleeved (using stainless) it ends up being a little harder on seals. As a measure i got about 60,000kms of road use with occassional track work.
One thing i did notice before a day in December at the track, was the fluid was very bad. Perhaps it was topped up by a mechanic using crap, or was just particularly dirty?!?!?!?! But i have heard rumour that if your fluid is really bad and you flush the fluid, then crap can become lodges in / against seals etc?
Anyway, just in case others fall victim to a re-sleeved master cylinder only lasting 2-3 years, and approx 80,000kms...whether thats the norm:confused:
https://www.sau.com.au/forums/topic/67599-brake-master-cyliners/
I put a new aftermarket clutch master cylinder in a corolla - it lasted about 5000kjm then gave up. Got an exchange as it was faulty - still a pain to change again. The next one was fine.
But although this is not relevant to you, when the mechanics pulled apart the leaking 5000km old cylinder they found what looked like old fluid inside and tried to blame me at first for not using new fluid. Turns out when they manufacture them they put some assembly oil in there so the seals dont dry out when they are on the shelves or shipping etc. Maybe the guys that resleeved yours put some kind of different oil inside. Not sure
Hard to know which way to go I guess..cheap aftermarket or resleeve old one.
My sleeved master cylinder lasted a whole .... ooh gee 30-50m if that :cheers:
After 6mths of mucking around I learnt it was best to just buy a brand new standard master cylinder from Japan.
:rofl::) :)
Isnt the OEM item like $440 ish though, versus the $70 for the aftermarket item?
Mines been fine running a os twinplate for nearly 5000 kms...std item n my car only got to 110,000kms (reading by the speedo cluster)
Ok, well after a few road tests and looking at the master cylinder, it appears thats not the problem:(
Basically it looks like my 324mm rotor upgrade using the std caliper is running into strife when using a slightly more aggressive pad, ie the Comp 9. With the RB74s i use to use it wasnt a problem, the compound seemed to have masked the problem.
So current thinking is that the pad sitting on the outer edge of the rotor is doing all the work, rather then the full face fo the pad, and for one...its overhating the reduced surface patch of the rotor...and two the pad had more knock off whuch is resulting in the spongy pedal.
So will have to have a closer look over the weekend, in the morning the car is being trial fitted with 6 pot APs and 343mm rotors, to see if they fit in my 17" wheels. If they do its food for thought, but the money would be better spent actually driving the car at the track, so what if the pedal doesnt feel as good:(
Try $200 to get your master cylinder sent away, sleeved, re-fitted or $450ish to get a brand new oem from Nissan Japan.
I've been there done that, no thanks... took a brand new oem to fix my issues.
$450! where are you guys shopping. Picked up a newie s14 master and a new slave 3 weeks ago for $130 from Nissan. Minor mods to the lines were required for the master and the thread had to be shortened to get the adjustment due to the cylinder being set a bit further back but the bore size is the same, total travel is the same.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
