Ok does anyone know of ANY companys that make intake manifolds for rb20's even if its just the top half.
also.. i saw it somewere in a magazine.. someone had put a standard rb26 intake manifold onto a rb20 and done tests.. (wish i new were the hell it was a saw this) anyone know wat needs to be done to get this to work..
im sure im not the only one that wants a intake mani which faces the front instead of this back across the engine making IC pipes 2 meters(exaduration) long... (also its a tight fit for rb20 in a s13) :)
ALSO to save people saying anything about the greddy plenums for rb25's... they dont fit rb20's :P
Cheers
Warrick
https://www.sau.com.au/forums/topic/67747-intake-manifolds/
There are a number of threads on this subject, I suggest you do a search. So you want to be able to change injectors easily (how often do you do that?) and you don't mind looosing power EVERYWHERE and having poor idle control. If you had done a search you would have read about why this occurs. I have posted up pictures of the RB26 plenum and the necessary fabrication required to fit an RB20, a search will show you that. The search button is your friend.:P
PS; did I mention do a search?
https://www.sau.com.au/forums/topic/67747-intake-manifolds/#findComment-1256840
hmm loses power everywere poor idle? :P hmm didnt think it would be that bad... its a pitty greddy or someone doesnt have something like the rb25 one for a rb20... :)
also.. spark plugs.. blah blah blah to tired to really think of other shit that you have to move.. were as front facing plenum would simply make it half the work.. meh i think sleep time almost or something like that :)
https://www.sau.com.au/forums/topic/67747-intake-manifolds/#findComment-1256851
Hopefully I'm not hi-jacking a thread here...
But I've been looking at purchasing an R32, which aparantly has an RB25 head and RB26 block. I won't mention the guys name as it is from this forum (people might be able to figure out which R32 or which guy it is, based upon this though).
He sent me a picture of the engine bay, and I was concerned about the amount of RB20 gear contained within (i.e. cam covers, timing belt cover, intake piping are all RB20 items and I can't see a VCT solenoid)
But it has does have an RB25 intake manifold. Anyone got any opinions on whether this would infact be an RB25 Head (probably a DE seeing as how its non-vct)
See attached pic:
https://www.sau.com.au/forums/topic/67747-intake-manifolds/#findComment-1258225
See attached pic:
It may not be an RB25DE cylinder head, it is a simple unbolt job to remove the VVT solenoid and actuator. RB20 cam covers cetainly fit.:(
https://www.sau.com.au/forums/topic/67747-intake-manifolds/#findComment-1258400
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
