  • Replies 114
Guest two.06l
NXTIME, I remember now you've got the twin 2835 high mounts damn for someone that asks a lot of questions you don't reveal much about yourself hahaha or is it your checking out the competition first :(
What gearbox you runing mate?
Tell us the specs mate, we're all friends here
hey ya big potato..funny thing is, i know of a guy that pretty much copied our build sheet. Was chatting to him on the weekend and is wondering why they arent making the power with the same tuner and dyno..
to pinch a line from Toohey's limited....
"It's all good mate"
I just want to wait until the damn car is actually up and running. It's been over 2 years and alot of bad luck and $$$ spent. Hoping to have it ready by April 9th. ;)
It's a stock(ish) R32 GTS-t anyway...
well, that is what the sticker on the bootlid says. ;)
Mate don't talk to me about builds its twice as hard when you start from scratch :( 14 months and counting
Its ok though we'd still like the specs its sort of like I'll show you mine if you show me yours but your not playing :)
I just want to wait until the damn car is actually up and running. It's been over 2 years and alot of bad luck and $$$ spent. Hoping to have it ready by April 9th. :(
well, that is what the sticker on the bootlid says. :)
Funny thing about buying modded imports is that it's all well and good when they are running, but since they are often near their deathbeds they turn into hell expensive projects... or left motionless in the garage. But it still can work out cheaper than building it locally.
Quite hard to hide the flared GT-R guards and call it a GTS, I doubt many people will get away with it.
Good luck with it, I'm sure it will be somewhat competitive on the local scene.
Not very hard considering the local scen fu(king SUCKS! AWD racing RWD is BULL$HIT!
Sports Compact Racing is garbage while:
RWD races AWD in the same series
and
DYO racing features minimum weights...
Adrian
Guest two.06l
and
Adrian
Guess whos 20lb over the minimum for TWO power adders.....????
I know, I know. I added up the costs of building it from scratch and didn't like the idea of another mortgage.
At least it will still fool all the wankers who won't know the difference. Plus, too many GTS-T owners have GT-R'd their cars, so I am getting one back by GTS-t'ing mine :( I even considered fitting a GTS-t wing! lol But have just gone for the wingless rear.
Thanks, I hope I have some better luck in the coming weeks.
PS, I'll play - PM's sent.
and
Adrian
Couldn't agree with you more. But untill there are much bigger numbers, the AWD v RWD categories are here to stay. DYO with minimum weights should be gone soon enough.
and
Adrian
It's all irrelevant considering the whole Sport Compact rules are now DYO. There's no motivation to build a quick car conforming to the rulebook when a stock auto can sweep the podium.
Just looking at the American scene, where it is still a heads up series, Supras are quicker than 4WD competitors. The added weight and resistance of 4WD isn't as great an advantage as you would think.
On the street it's a different matter :(
DYO featuring minimum weights is irrelevant while S.C. racing is DYO? WTF? I don't care that there are no fast 4WD's in the USA - doesn't affect me.
Lets get a subscribed field of RWD cars and then bin these cheaterer fu(ks in GTR's !!! :( lol
Adrian
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
