  • Replies 93
cat /dev/rnd > /dev/snd
I used linix for ages, though Debian (apt is the greatest loonix tool ever)...
Might install it on my old box as a "**** around" server, but I'd never go back to using it as a desktop.. Way too involved and time consuming trying to get everything windows-based to work :cheers:
https://www.sau.com.au/forums/topic/68336-damn-computers/#findComment-1267877
Yeah, well I was sick of windows crashing all the time and the 400 spyware/adware a month.
I don't think I can get spyware/adware anymore so that problem is solved. I still have a dual boot with XP running.
BTW, I still have a running copy of DOS 6.22, ALL Windows Versions, Redhat 7 and 9 and Fedora Core3.
you say....what the hell do you know about OS's
I'm the f$%ken OS MASTER.
Linux aint that bad. Especially this Fedora. It way outpowers windows in all ways and has less vulnerabilities. Plus I was being attacked by members of Andre NET every day. I had to run 4 firewalls just to stay alive. Now...no probs and I have a massive artilary at my disposal....so now I go to war.
https://www.sau.com.au/forums/topic/68336-damn-computers/#findComment-1268357
Are you new to computers?
1 x hardwire firewall/router
1 x XP install with personal firewall running and all non-essential services blocked (remember, DENY all and allow each port individually!)
1 x MS Anti Spyware
No problems.
Just use common sense. "Britneynaked.jpg..................pif" is still a pif. "Click here for free porn" is never free porn. Accepting files from people you dont know is stupid. Running an FTP/HTTP on common ports is asking to be pwned. Using MSN is asking to be pwned. Using IE in anything other than "Restriced Zones" is asking to be pwned. Etc.
For the casual hax0r, a loonix box with a default install is easier to hop into than a windows box :rofl: Hello plenty of installed services that are all open and left with default settings!
I'm interested to know how linux "outpowers" windows too, is this a tractor pulling contest? X Windows is slow and clunky and needs a 3Ghz machine to run anything more hardcore than KDE.
https://www.sau.com.au/forums/topic/68336-damn-computers/#findComment-1268502
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
