Hey guyz. this is not a big deal but still i hate it when things are not right. Sometimes when i let down the handbrake the handbrake light on the dash still lights up. Sometimes it goes off when i drop it but sometimes it stays on for the whole time im driving.
Anyone else had this problem? and a sloution to it... without cutting the cables ;)
:cheers:
https://www.sau.com.au/forums/topic/68424-annoying/
As a quick guess, do you need to lubricate the switch (the one next to the handbrake with the spring)? It may be getting sticky and not operating properly by returning to the 'off' position once the handbrake is lowered.
It's in the coloured box (in the attachment).
edit: you can't see it (the switch) in the pic (it's for indicative purposes only :cheers:), but if you take the console out (~5mins max) that's where the switch is on the R32. I'd expect it to be in the same spot on your car too.
https://www.sau.com.au/forums/topic/68424-annoying/#findComment-1269080
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
