Hi Luke, cam bracket bolts (in Nissan speak) are torqued to 0.92 to 1.2 kg-mm.
The Nissan R32 manual says start at #1 (front bearing) pair, then #7 (rear bearing) pair, then #2, then #5, then #3, then #4. That's 14 bolts and its the same for RB20/25/26.
:thumbsup:
The installation order is from the middle cam cap and work outwards (total 14 bolts).
Removal sequence is from the outside and work in.
Hope that clarifies.
thats the way i would be doing it aswell....some get it totally wrong and break it in half :) i usually put the middle one on the turn the bolt 3 turns or so,then work outside and continue until it pulls down even
thats the way i would be doing it aswell....some get it totally wrong and break it in half ;) i usually put the middle one on the turn the bolt 3 turns or so,then work outside and continue until it pulls down even
Yep spot on, do it in stages to pull the camshafts down evenly, not just it one hit.
:cheers:
I have a Nissan manuals in front of me as well, both the RB26 and RB25 manual says its from the centre out to tighten?
Surely this makes sense, as its the same sequence to what a cylinder head is tightened.
If you went from the outside in, the camshaft could bind and snap. (Technically possible, but realistically unlikely if the head isn't warped and the cam is still pulled down evenly)
Would you like it posted up here?
Anyone know where I can buy a 'sensitive' torque wrench to do cam caps? I want to change the cams in my SR20, and every hardware and auto store I go to, they dont have torque wrenches which can measure below 40nM. Ridiculous...
No, 540 degrees is their suggested amount to turn each nut in sequence so you tighten them gradually until they nip up (caps bottom) THEN you tighten them to about 11Nm as per the TORQUE setting in the picture.
I used a little 3/8" drive torque wrench that goes from basically zero to 20 odd Nm. Works a treat.
11 Nm does not feel tight enough but all techo sort of stuff with cam caps are about that figure so I did them up to 12Nm. haha
Just a note for everyone - The above manual for the RB26 has the baffle plates on caps 3&4 but on the RB25 (mine at least) they go on caps 6 and 7. The baffling in the rocker covers are different and that is why the breather hoses come out at a different place. I believe you can't get this wrong anyway because the rocker covers probably wouldn't go on.
At the end of it all just do up the cam caps very gradually so you don't snap the cam!
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
