  • 2 years later...
$140 wtf who are they kidding... Is it the rubber that is on the windscreen, like between it and the plastic? Cause mine curves at both ends
Yeah mines curved at both end too... I removed it yesterday and gonna give the clarke rubber thing a go today :D
Cool i thought it was that, i took it off yesterday and now its even more screwed. Thanks for the photos vietorious they say a thousand words, now i just have to be bothered to do it but at least the rain has stopped.
Edited by WET-25T
How did u take it off?
I sprayed my windscreen wipers on sat (was very gay with the rain cause i had to drive to get more spray paint :) ) anyways you have to take off both windscreen wipers which is easy, and in the engine bay you will see a long rubber thing going from the drivers side to passengers side which is sitting on the plastic you wanna take off.
So without breaking any of the clips take this rubber off then the plastic you want has clips holding it down so put your fingers under it and once again without breaking the clips pop it off, its not hard you just have to be careful.
I didnt paint mine and dont know what you should use.
Edited by WET-25T
  • 3 months later...
  • 3 weeks later...
I sanded mine back to get rid of bumps, then cleaned then if i can remember correctly i cleaned them with metho, then sprayed them with an undercoad that makes the paint stick better, then used matt black spray paint, or mapp black? cant remember lol.
Anyways when u go to buy it tell the guy what its for and he should be compitent to guide you in the right path.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
