I've recorded base map for the R32 RB20DET AP Engineering PowerFC.
For those that are curious check it out.
I will post up the modified map once its tuned to suit the 3ltr.
If any one has done similiar I would be interested to check out the RB25DET base map.
Or if you have an RB30DET I would be very interested in checking out its map.
https://www.sau.com.au/forums/topic/68580-ap_powerfc_rb20det_base-mapxls/
At first I had an issue with Idle.
I took the car for a drive so it was nice and warm.
Pulled the plug off the AAC.
Set idle to 650rpm.
Connected the AAC plug back up.
Reset the PowerFC and took it through its 30min learn.
10min idle, 10min idle elec load, 10min idle a/c.
I now have a 100% repeatable stable idle. No hunting and no occasional 1100rpm idle when pulling up at the lights.
Hmmm interesting, mine idles great with the AAC plug out too. I don't really want to reset the power fc yet and loose my settings. Pity i havent got a laptop so i can record the settings straight into xls. I'll have to do it the long way
With mine the trick was to get the car idling ever so slightly under what its set in the powerfc, i.e not going over the rpm set in the pfc.
My idle vary's ~25rpm up and down. Without the AAC plug hooked up it would idle from 620-640 and some times 650rpm. But not going over.
Then it HAS to be reset to do the learn thing again.
I tried simply adjusting the PowerFC's idle setting up then back down again in an attempt to get it to re-learn however it caused MAJOR idle hunt issues and didn't re-learn.
Write down all your maps, post them here and then fiddle with the idle. :D
Hope it works for you. :)
So back to the Z32.. What you are saying is plugging up the Z32 afm does alter the load readings when map tracing on WOT?
Like now it reads load point 19 at WOT 2000rpm. With the Z32 will it drop that to say for example 17 or 16?
My idle was pretty good when i plugged in the pfc after the learn process.
But then i put the z32 in and i've had to add more fuel to stablise the idle at low rpm, It would hunt around and sit at 900rpm all the time. Now its around 670rpm.
I'm thinking of resetting the power fc again and doing the learn process with the z32 in there.
Yes exactly, as the Z32 can read more voltage your load points will drop. For instance, i am using load point 16 between 4000rpm and 5000rpm and im running 18.4psi. If i drop it back to 15psi, it reads to load 14.
Yep thats right.. Did you take notice the before and after with the stock afm vs the Z32?
Mine with the stock AFM will hit load point 18 from as low as 2000rpm when accelerating from a low speed in second.
The reason I'm asking the question is if I fit the Z32 up will it require a re-tune?
I know what your saying Joel.I installed the Z32 a few days before I got it tuned so i can't help ya there.
Here is my tune with GTR injectors,GT2535 11psi :Oops:
Over 12 on the load it's not tuned so any more than 15psi it has a fit and injectors hit 100% duty!!
  • 2 years later...
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
    • Brakes definitely won't make him faster. They only slow you down. 😛
