  • 4 weeks later...
Can't put my fingure on it, but looks wierd.. kinda like the wheel base is a bit to short and sitting a bit to '4wd' like.
The mesh looks a bit fake, but besides that impressive!
i reckon its becuase the rear guards arent modeled right... they dont have the crease up them like a gtr should
