Theme: Showdown Time Attack Battle
Clubman Track for 1.8 hours,
Sprint Track for the next 1.8 hours.
Showdown on the National Circuit.
Top 8 contenders, Sudden Death - 3 Lap Time Attack Lap Battle.
Day: Sunday May 22. Start 7:30am, on track from 8:30 to 12:30 (4 hours)
Cost: Should cost approx $120 per driver (pending numbers)
Maximum Starters: 48
Laps: 1 warm up, 5 hot, 1 cool down. Max. 8 cars per group on track
Payment: I will need everyone to PM me their email address so I can send you my bank account details. I need to have the money in full 2 weeks before the event to pay for the track. No refunds within the 2 weeks of the event, but replacements are cool. Unless we have a full booking, then refunds are also cool.
Equipment: All the regular Track Day guys will be familiar with the timing gear we have. 1/100th of a second lap times, main straight trap speeds, track and ambient temperatures, Giant sign to show lap times live. Best lap order shown at the end of each session.
Required: The requirements are the same as the normal sprint days. Long sleeve clothing - wrist to ankle to neck. Helmet and covered shoes. Also a current drivers license and a QR license (annual license about $55 and can be bought on the day)
NOTE: All the rules etc are in my standard track day email which I will send you when you PM me your email address. Also mention if you want to be on the mailing list or are just in for this day.
For the volunteer list, if we get several people we can swap roles - so not one person is stuck with a job for the whole session.
Chequered Flag: Strutto
Flag Man 1: SmoothLine
Flag Man 2:
Timing Helper 1:QMK04Z
Timing Helper 2:
Pit Lane Controller: BND
Pit Lane Organiser:
Starters:
1. jlnewton
2. 33NIZ
3. Nismo_Boy
4. Genesis
5. Predator
6. GTRman1992
7. Slamm
8. ImpulR33R
9. TeamKrazy
10. maccattack
11. Fullysic
12. Rhinorebel
13. stealth
14. WiZardOz
15. TOY 33
16. GTR CAM
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
https://www.sau.com.au/forums/topic/68700-showdown-2005-the-booking/
in.. I was up for the May track day anyhow..
dress code is yes.. plus you need a giant pea on your head josh.. to match your brain
hmm.. hopefully I can get an upgrade done in time or I'll be last .. that can't be good..
I think its still a bit of EOI If I am guessing correctly?
So we will need at least 15 cars or it is not worth going ahead with the day.
p.s. you guys who don't have one will also have to factor in $50 for a QR racing licence I believe.. this requires a valid drivers licence i think as well.. i.e. if you have lost your licence currently you might have to sit out.
Can someone confirm or deny this to a CERTAINTY because at willowbank (drag strip) many were sure you required a non suspended provisional drivers license to race but thats not the case as I raced there on l's way ago......im not having a go at you gordo I just want to know as on the day I will have a license however it will most likely be lacking points.....ie suspended. I doubt this should matter as having a license doesnt even matter for getting a cams license or andra license etc..if anyone knows, let me know.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
