Howdy all,
I've just recieved my new happy A'pexi Super Happy Fun Power Funnel airfilter, and I was pondering what I had read in the AFM cleaning thread, whether I should do it or not.
Well, I did it. Here's the pictures for the people who aren't sure.
Here's the old HKS filter pod, dirty as a dog's bum, along with the rest of the engine bay. On the right is the AFM, waiting for the cleaning of a lifetime.
I decided to take the HKS pod and the AFM off in one piece, here on the left, I've undone the hose clamp and wiggled the AFM out... tight fit. There's the sensor data cable, give that tab on the left a really really good squeeze, it should click, and it should pop straight off.
That's the front mesh there, it was utterly black when I got it out, I wiped all the gunk off the front, but I still ran a towel inside it later on. You can see some of the crap inside the afm, and this was after a blast with the contact cleaner
Oh, here's the contact cleaner now, getting to know the AFM on their first date. The large chunks of wood are from an unrelated project. The rear mesh, or remains thereof, is on the right.
The new air pod and the AFM meet, you can see on the right the total reaming of the old mesh area place thingy. That first photo is quite arty, with the ScibyLine just out of focus on the right... I could be a marketing photographer... or... er... maybe not.
The pod and afm move in together, they certainly seem happy together so far, and all their bits fit perfectly. Maybe I'll here the sucky-sucky of little filters in the engine bay soon... and yes, the socket set is a new mod, good for another 30hp at the wheels. With a bit of tweaking on the 12mm socket, the ScibyLine will run 9's. True shit, bro.
Also reset the computer, and it all seems happy. Runs and idles much better, revs much freer down low and I accidentally... well... almost accidentally... okay fine, I dropped the clutch at about 5k and burnt the clutch for the 3rd time. You happy now?? :D
(Cleaning out the AFM seems to not hurt anything and I can see how it would be beneficial. It's part of my servicing now.)
speaking of burning clutches I "accidently" did the same thing and had a horrible smell lingering around for a while....
is this a good thing? im thinking not how much abuse will the standard clutch take...(maybe this should be a new thread) oh well..
Meh, I started the thread, so I'll forgive you...
No, stinky stinks are bad.
In this case, if you give it a bit and it feels like the engine is bellowing but the car ain't moving like it should, or like the wheels might be spinning, but there's no screeching, then the clutch is slipping. You'll get a horrible smell through the aircon. Just buy a new clutch plate because once they start dying, they die faster and faster.
they certainly do!!!
i've just picked up an OS Twin Plate clutch... so hopefully no more slippage.
I'm looking at getting one of those Filters... i don't have an AFM at the moment, running MAP. But as i am in melbourne and there isn't anyone to tune HKS FCON's properly, i'm thinking of changing over to a Power FC and Z32 AFM
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
