i ordered some greddy cam gears from these guys on the 14th and its now the 30th and still no gears or any confirmation of the gears being sent.
the website still says processing, but how long does it take?
i was under the impression that they would let me know if it was gonna be awhile, and 15 days is quite some time.
this is my first time ordering from them but so far im not impressed......
any thoughts?
carl
https://www.sau.com.au/forums/topic/68779-nenguncom/
I've recently ordered for the first time from nengun as well. My order has taken longer than expected by about three weeks. Initially I was made aware by nengun to expect a two week delay, however another three weeks later on top of that and had no word. My order was paid and placed by about the 25th last month and only yesterday changed from 'Processing' to ‘Complete’: meaning I'm waiting for my EMS tracking # once it leaves the shores of Japan.
I hounded Nengun with inquires for a while with no response back. I can only suggest you try the same? As I understand it, most of their correspondence is automated.
For all intensive purposes I haven't been worried about not receiving the order and can't complain about the deal I'm getting. just a bit miffed with the customer service side of things.
Ordered parts from Japan a few time from different companies and had to wait longer than expected for all (inc. car).
Waiting definitely sucks, best of luck with it.
https://www.sau.com.au/forums/topic/68779-nenguncom/#findComment-1274442
haha need a nengun / greenline FAQ thread :D
anyway carl h, just depends how long it takes to come into stock
one order i placed took about a month to arrive
then another order took one and a half weeks only
if they confirmed that your payment has been recieved then its just a matter of waiting a few weeks... it will come
https://www.sau.com.au/forums/topic/68779-nenguncom/#findComment-1274813
I ordered a PowerFC from them on the 17th, it took about a week for them to process and recieve my payment. I was worried so I sent them an e-mail and got a non-automated responce the same day.
On their site it does say that some delays can be expected due to availability, I'm not really complaining with the price I got it for.
https://www.sau.com.au/forums/topic/68779-nenguncom/#findComment-1274931
i bought avc-r off nengun before chrissy. Took about 10 days to arrive after payment. I don't think you should worry man, a LOT of people have done business with nengun and they all got their stuff.
If it takes a little longer, at least the price is a lot cheaper than aus. Still, if you worried, try and email him to make sure nothing is wrong.
good luck
https://www.sau.com.au/forums/topic/68779-nenguncom/#findComment-1275059
yeah, i got an email back from them today.
looks like the cam gears are supposed to be in sometime this week then shipping out to me next week.
sucks waiting tho but hey ive been without boost because i was upgrading the old rb20 while it was out of the car for nearlt 7 months now, whats a few more weeks.
https://www.sau.com.au/forums/topic/68779-nenguncom/#findComment-1275501
sometimes your stuff is in the postoffice waiting for you but the idiot post man doesnt leave a note...
i waited nearly 2months for my coils, it said completed on the nengun webiste for at least 4 weeks...anyways i called up the post office and gave em the EMS number and it had been sitting there for 2 weeks...bastards!!!
https://www.sau.com.au/forums/topic/68779-nenguncom/#findComment-1275502
Great, another Nengun thread.
and closed :(
Guys, there is a search button.
PLEASE USE IT!!!!!!!!!!!!!!!
An order is like anything else, in stock... fast delivery.
not in stock... it takes longer.
if you have issues ... dont post here, e-mail brett himself.
as if anyone here will know where your specific goods are!
You've got the tracking numbers and everything anyhow
https://www.sau.com.au/forums/topic/68779-nenguncom/#findComment-1275558
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
