Hi Guys,
Has anyone heard of Quantum Racing Suspension, the are a UK company that makes suspension for race cars. I have a set of their height and rate adjustable coil-overs. These things are made of aluminum (see "Light as F%#*"), and have spring rates of 10kg/mm (see "Stiff as F%#*").
I have tried the net to little avail, only being featured in Mini Cooper racing. The latest HPI, GTR Special, has an article at the back with the "Trial" GTR have a set.
If anyone knows a seller or website could you please let me know.
See'ya:burnout:
https://www.sau.com.au/forums/topic/6881-quantum-racing-suspension/
They are manufactured for TRIAL, and TRIAL puts their brand name on them, and resells them.
There are different specs:
F8K/R6K (Street)
F10K/R8K (Circuit)
F10K/R8K (Street)
F12K/R10K (Circuit)
Excellent coilovers. They range in price from 348,000 - 425,000 for R33 GTS-t models.
Thanks for the response Maddness and Merli,
Its good to see that someone else has heard of these coilovers.
Yeah I do feel lucky as I got them pretty cheap off a friend who imports cars. I will have to attempt to get a sticker for it, like on the Trial GTR in HPI.
See'ya:burnout:
  • 1 year later...
well so far I have contacted these people - www.shockreco.com.au - and I am awaiting a reply. I have also spoken to the guy I got them off, and he is lending me a let of shocks and getting in touch with a place in Melbourne about rebuilding it
Has yours gone a bit clunky as well? I think becasue the oil has come out, the piston is moving about a bit. Hopefully they can be repaired, as they are awesome :thumbsup:
I like how hard they are, as with 225x16 on 16x7.5 rims, it makes up for a bit of sidewall flex and makes them grip really well
Yeah, I am in pretty well the same boat
I have been quoted $242ea for adjustable Bilstiens, and without checking, hopefully I can use the springs of the Quantums
either way its going to be a bit of a pain in the ass. The way I look at it, is if one has gone, the others must be close, so it might pay for me to get brand new Bilstiens, which are fully re-buildable
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
