hey all
I havent been on a decent cruise for some time now and was thinking of going for a run up the Bells Line of Road to Katoomba sometime soon.... was going to leave from Thornleigh Macca's and head down through the Galston Gorge, out toward Wisemans Ferry and hang a left towards Windsor/Pit Town. From there a small cruise through the heart of Windsor and out for a nice drive through some twisty's....
Was thinking of the weekend after Compak Attak, Saturday the 16th April, as its cold enough to make it a nice turbo night, but not cold enough to come across any black ice or force us to stay in our cars cause its just unbearably cold. Meet point as above would be Thornleigh Macca's as close to 10pm for a 10.30 latest leave.
Would anyone from SAU be interested in a bit of a "spirited" drive at all???
Brad
https://www.sau.com.au/forums/topic/68857-eoi-bells-line-of-road-cruise/
  • Replies 61
Babak took me/let me drive your old car, I'm still amazed that you were able to part with it! :wassup:
We did a 2nd gear roll on the way home tonight, and the way the GTR brutally pulled away from me when it hit boost was awesome... It's like I was standing still. The 330CI with 170kw isn't a slouch either!
Then when I pull up next to him, the bastaard leans across and says "and that's on wastegate pressure!"
what car have u got merli ?
mate, considering his avatar is a BMW badge, and he just posted right above you about driving his 330CI I think I will hazzard a guess and say that merli in fact drives a school bus and has a carrera GT for weekends.
well he used to have that "sexually frustrated purple" r33 GTR for his logo, and is on a skyline forum, which made sence, but now says he has a GT and has a BM logo. and something bout a 330ci.... merli do u have a licence ?
merli hasn't held a licence since he got the Carrera GT about 2 months ago. he had it all of 3 days, then points gooooone.
Didn't last long did it mate! :rofl: aweseome car though.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
