I recieved 4 today from the following email addresses..
[email protected]
[email protected]
[email protected]
[email protected]
I actually just noticed that that these are due to me being a member of Skylines Downunder.
This is a message from FastJohny at Skylines Downunder Discussion Forums ( http://forums.skylinesdownunder.co.nz/index.php ). The Skylines Downunder Discussion Forums owners cannot accept any responsibility for the contents of the email
i tried PM'ing one of the admins on SDU with the fix for it that I used on here, he said he didn't have access to the forum's files to modify the code... so I guess that means we have to wait till the owner can fix it.
yeah i got it thru SDU too
and also this forum which i am not even a member of:
This is a message from energydri at Rally Forum ( http://www.rallyforum.com/forums/index.php ).
The Rally Forum owners cannot accept any responsibility for the contents of the email. If this message is spam please forward it to [email protected]
To email energydri, you can use this online form:
http://www.rallyforum.com/forums/member.ph...rm&userid=21051
OR, by email:
mailto:[email protected]
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
