Needed to have paided online by thursday and the amount is in one of Jayces posts a bit further up.  $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35 $35  Sunday
Or you can pay cash on the day...as online payments are all closed now...
  • Replies 116
ah not happy jan our rollout yesterday did not go as planned as it in it has taken us alot longer than we expected so much so that we all need to go back in today so will not be able to make it sorry guys was really looking forward to watching this.
Just posted on Valvebounce.com:
"OK:a great day was had by all,I reckon! Aside from some minor technical hiccups,all went well,with some really good times set and some decent battles being raced on the track... Everyone seemed to be in high spirits,with no major carnage(well,race_snooze & Jester had a fair coming together)and everyone dealt well with the intermitent showers. Of the top qualifiers,Dan' was "the man" with a blistering 26.64,and wound up taking out the "A" final with a 27.03 on a damp track. Most will know cart # 11 was THE one to have,and it just might've helped in Dan's domination of the timesheets... In the "B" final,Anthony took line honours with a 31.02(in cart #11...!).As for how each club went,here's each club and the positions their members finished in:
Syndicate:7th,9th,16th and 17th
ACT WRX:4th,6th,8th13th and 15th
SAU:10th,18th and 19th
Valvebounce.com:1st,3rd and 11th
REact:2nd,5th and 12th
and,last but not least:VMPCA:14th and "too busy to drive,'cause I'm writing as fast as I can"...LOL! Actually,I did a 27.37 at one point there;a new P.B. for me,so next time,LOOK OUT,you lot! Strangely,Glenn went faster than me earlier in the day,but a damp track obviously took the edge off his times,too!
All in all,I think we're all a bunch of fairly competitive people(with James from SAU taking time off from being serious to throw in a display of "Dorifto"),and I'll put it out there to all:do you want ALL the times and positions listed,or would you rather a discreet PM?"
I WAS THE FASTEST SAU DRIVER!!!! I only did a 27.74 though (pathetic seeing as my P.B is 27.11) but it was in a slower kart.
It was a really fun day and it got even more fun when the rain came! James is such a show off (I wish I could drift as good as him).
I have to say that I was dissapointed at not getting a quick kart all day, but I had fun anyway... When the next one comes around and I DO get one of the quick karts = Watch out Jayce!
I have to say thanks once again to Jayce and Glenn for organising such a good event, I also have to say to all the people who didnt turn up (Frink, etc...) YOU MISSED OUT, PIKERS!!!! Hehehehe :)
Who else feels like they have gone 10 rounds with Tyson?
Thanks to Jayce and Erica for the time recording and organisation skills. Couldn't have done it without them.
BTW - I officially suck at the karts, Dan from valvebounce.com ran out the winner! woohoo! Next time SAU, next time. ;)
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
