Hi all,
Just want to confirm something...currently have an R34 with stock 17s wrapped with 225/45/17 rubber...if i was to go with some 18s would the correct tyre specs be 225/40/18 ? or 225/45/18? Bear in mind we wanna keep the speedo readings accurate. Thanks for your input in advance.
https://www.sau.com.au/forums/topic/69131-tyre-specs-question/
So long as the rolling diameter is the same. By this I mean if your previous tyre wheel combo had a diameter of x and your new tyre and wheel combo has the same diameter you're fine.
Search through some other threads or google as people have posted some links to a tyre calculator that will tell you the rolling diameter from inputting your wheel and tyre sizes.
The correct size will be 225/40-18 :(
If the width doesn't change (ie 225 wide) then for every 1 inch bigger take 5% off the profile % (ie 45 to 40)
Try it on this Tyre size calculator to see for yourself - http://www.miata.net/garage/tirecalc.html
Hope that helps........................................IAnH
Get hold of the technical brochure for the tyre brand / style you intend to use. It will include the rolling diametr of each size. Then you can compare your current tyres to your proposed new tyres.
Mate, if you going fo r18's you want to go for wider rims. I'd suggest 18x8 on the front and 18x9 on the back with 225/40/18 on the front and 255/35/18 on the back.
You could go to 235 and and 265 with very little change in circumference though.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
