Hi
I want to keep the tyres that I imported my car with as they are in good condition etc, but im not sure if they have the correct Australian rating. The only markings I can see is a V4UY on the 255's on the rear and a V40L on the 235's on the front. As well all tyres have a really small circle symbol with a squiggly line going through it.
Also my tyres are all the same brand/version but these markings are only on the left side tyres and not on the right. Is that gonna be an issue?
Cheers,
Dane
EDIT: actually now that I look closer it might just be that the tyres are on the wrong way on the right hand side - so the markings are on the inside sidewall of the tyres.
https://www.sau.com.au/forums/topic/69160-import-tyres/
At least 4 tread wear indicators,
The tyres fitted to a 15 year old car and the old ones off your SEVS car need a few things,
Tyres fitted comply with DOT or E mark specifications,
All tyres fitted to the vehicle of the same type of ‘Carcass’ construction,
Rims are marked according to ADR 24,
https://www.sau.com.au/forums/topic/69160-import-tyres/#findComment-1284669
i changed my rears as they didn't have the markings.. in the end the tyres I bought didn't have the E-rating markers either, but they were sold locally.. lol.. engineer passed them without any fuss.
but this was up in QLD
That scribbly circle is a j/s marking which I have been informed. has only recently been accepted as a valid tyre standard in Australia.
https://www.sau.com.au/forums/topic/69160-import-tyres/#findComment-1289199
My car passed through inspection with Jap Tyres all round. No E or DOT mark to be seen. They have a JIS stamp and they deemed that suitable.
This is for WA so might vary from state to state.
hmm.. i dont think my slicks will make it thru tho :wassup:
https://www.sau.com.au/forums/topic/69160-import-tyres/#findComment-1299254
JIS is Japanese Industry Standard and by itself is not sufficient to certify in Victoria for 15yo. Some tyres have a combination of JIS, DOT and or E marking. the latter 2 are the minimum requirement here in Vic.
Still others are ok if complied on the dotars site under manufacturer, so in the end - leave it to your engineer.
regards Paul
https://www.sau.com.au/forums/topic/69160-import-tyres/#findComment-1302145
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
